how much boost can the lsj sc handle?
Old Nov 10, 2013 | 01:50 PM
kobe77's Avatar
Just wondering how much boost I can run on stock internals 05 cobalt sc. Has gm stage 2 upgrade, ported m62, ls4 tb, 3" stainless header back zzp exhaust hp tuned. Currently only running 15psi.
Old Nov 10, 2013 | 01:58 PM
BlkWdoSS's Avatar
Search function helps here, other than that, you cant just increase boost on a SC, you have to change the pulley to increase boost.
You wont be able to push enough power with the M62 to blow it up. If you do blow it up it will be because of other things.
Old Nov 10, 2013 | 02:01 PM
574's Avatar
574
35psi
Old Nov 10, 2013 | 02:07 PM
One meelion only if you put your pinky in your mouth first
Old Nov 10, 2013 | 02:13 PM
574's Avatar
574
OP name is kobe77 I wonder if it is COBE in disguise
Old Nov 10, 2013 | 02:42 PM
Gelladuga69's Avatar
Over 9000
Old Nov 10, 2013 | 05:40 PM
yellowsupercharged06's Avatar
Just put the belt on the snout and its the perfect setup
Old Nov 10, 2013 | 06:39 PM
bumm81890's Avatar
Over 9000
lol was waiting for it
Old Nov 10, 2013 | 06:51 PM
Over 9000
Def well over
Old Nov 10, 2013 | 06:59 PM
Rittwage1994's Avatar
only upgrades i have is OTTP stage 2 from chevy and muffler delete and i run 19psi if i fully open it up just fine
Old Nov 11, 2013 | 02:50 PM
kobe77's Avatar
Really eh. I was thinkin of running 17 or 18 on the streets then maybe up to 20 at the track. Just wasn't sure of what the lsj can take. Definitely a solid motor thus far
Old Nov 11, 2013 | 02:53 PM
soo how do you plan on changing your boost at the track ?
boost isnt your issue, the heat soak will be
Old Nov 11, 2013 | 02:58 PM
574's Avatar
574
Just turn that knob yo
Old Nov 11, 2013 | 03:10 PM
nhanson's Avatar
15 psi is max. 16+ and you will blow it up.
These LSJs arent made very tough...
Old Nov 12, 2013 | 10:02 AM
mrbelvedere's Avatar
bull **** the tune will be the deciding factor of longevity
Old Nov 12, 2013 | 10:04 AM
574's Avatar
574
Lol John he was trolling
Old Nov 12, 2013 | 10:08 AM
wtf is trolling
Old Nov 12, 2013 | 10:13 AM
Squints's Avatar
Saw the same thing and got worried(thought I was out of popcorn)
Old Nov 12, 2013 | 10:21 AM
Staged07SS's Avatar
Administrator
Administrator
Search!!
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
