How to remove stock boost gauge?
Old May 24, 2006 | 08:22 PM
Nuclear's Avatar
any one have any info or tips on removing and replacing the boost guage?
Old May 24, 2006 | 08:24 PM
powerbalt4020's Avatar
ive been wondering the same thing
Old May 24, 2006 | 08:53 PM
2006ArrivalBlueSS's Avatar
It's so easy.
Step 1: Remove the screw cover in the upper part of the A pillar cover.
Step 2: Remove the screw securing the A pillar cover (7 mm socket).
Step 3: From the top of the A pillar cover, gently pry it away. There are two clips securing the cover at the middle and the bottom of the A pillar cover which just snap out.
Step 4: Unplug the connector from the boost gauge.
Step 5: Loosen two nuts securing the gauge to the inner tubing of the A pillar cover.
Voila!! Replace with any gauge you wish - the Aeroforce is a good starting point!!
Old May 24, 2006 | 09:41 PM
Xenozx's Avatar
Yea 1 bolt holds it in place. Pop that out and then just pull and it snaps right out. I have photos Ill post later.
Old May 24, 2006 | 09:59 PM
Nuclear's Avatar
thanks guys pics would be cool too
Old May 25, 2006 | 12:31 AM
Asphalt Assault's Avatar
Click on my CARDOMAIN link in my sig.
look up the install for shift light on page 4. Lots of pics which will help you.
Dont for get to rate my car and do my poll on there. lllol Thanks
Old Mar 10, 2007 | 01:15 PM
stvn's Avatar
if you replace the stock boost gauge with an auto meter boost gauge, will it void the warrenty?
Old Mar 10, 2007 | 01:59 PM
Cobalt_Supercharged's Avatar
No it shouldn't. The dealerships I have been to haven't said a word about mine.
BTW: There are 2 How To's written up for this.
https://www.cobaltss.net/forums/show...al+boost+gauge
With pictures
Old Mar 10, 2007 | 02:00 PM
HotWheelz's Avatar
https://www.cobaltss.net/forums/how-guide-43/how-install-interceptor-d-22220/
Check this HOW TO out. It has pics showing how to take the piller cover off and then remove the guage.
Old Mar 11, 2007 | 07:25 PM
stvn's Avatar
is our boost/vac guage, a mechanical gauge, or full sweep electric gauge. im buying a new gauge and i dont know which one to buy, please help me!!!!!
Old Mar 11, 2007 | 09:35 PM
stonny9's Avatar
u can do the removal and install in 15 mins
full sweep electrical guage
Old Mar 12, 2007 | 05:20 PM
stvn's Avatar
i know this might sound stupid, but will an aftermarket gauge turn on when the head lights turn on, or do you have to run a separet switch to turn the light on. lol i hope this aint a stupid question.
Old Mar 12, 2007 | 05:33 PM
retrop's Avatar
If you use the wires that are for the stock gauge it will come on when you turn the key.
Why are you changing the gauge anyway? Especially with just a different boost gauge.....seems like a waste
Old Mar 12, 2007 | 05:39 PM
stvn's Avatar
what do you mean stock wires? you dont have to run new ones. im getting a new boost/vac gauge a autometer c2 because i like the light, and im also getting a auto meter air fuel ratio gauge, and a aeroforce interceptor
Old Mar 12, 2007 | 05:49 PM
retrop's Avatar
I thought you were swapping it out for another electrical not mechanical.
In any case there are 4 (if i remember correctly) electrical wires to the harness for the stock gauge, splicing into them will give you any power to need for the new gauge as soon as the key is turned on.
Oh and don not try to run the Interceptor and AEM wideband (if you go that route) off the same fuse...AEM draws too much power.
Old Mar 12, 2007 | 05:51 PM
stvn's Avatar
ok, so then what is better a electrical gauge or a mechanical gauge. ok i wont
Old Mar 12, 2007 | 05:54 PM
retrop's Avatar
That is entirely up to you, most people have left the stock gauge or removed the boost gauge entirely. I think a better option than just replacing it with a different boost gauge would be to get dual interceptors and monitor boost on one of the 4 channels you would have.
Old Mar 12, 2007 | 05:57 PM
stvn's Avatar
but those are too expensive. what would you get a mechanical gauge or a electrical gauge?
Old Mar 12, 2007 | 06:04 PM
retrop's Avatar
I guess stick with electrical. All the wiring is there and you won't have to run the vacuum line through the firewall. But again that is up to you.
Old Mar 12, 2007 | 06:08 PM
stvn's Avatar
which is more accurate.
Old Mar 12, 2007 | 06:15 PM
Ryuu600's Avatar
Um. The stock guage is an Autometer so why replace it with another Autometer
Old Mar 12, 2007 | 06:16 PM
stvn's Avatar
because i like the c2 gauge because i like the blue light
Old Mar 12, 2007 | 06:26 PM
Ryuu600's Avatar
Ah. In that case I would stick with the electrical for ease of installation. I don't know how hard it would be in the 'Balt to run the vacuum line but in my Passat it was a pain and I never got a good seal on the back of the gauge so I never had a consistent boost reading.
Old Mar 12, 2007 | 06:43 PM
stvn's Avatar
oh ok, but with a mechanical all you have to run is a vacuum line and a power and ground wire?
Old Mar 12, 2007 | 07:02 PM
Ryuu600's Avatar
yep. the power and ground for the light and the vacuum for the operation. The vacuum line being spliced into an existing line attached to the manifold
