how to tell
its the zzp one cause i htought bout cutting it out all together btu didnt know if i would have a code all the time just looking at options cause its going on tomoro
Ya u will have a code (if u gut it)but u can have someone hp tuners turn it off... and to check to see if it look inside the cat but if u can't see it u can put it on ur car and let ur comp. Cycle and it will throw a code for catalytic ineffiacne if its clogged
higher boost levels than normal, loss of performance, and possibly higher IAT2's
also, if you dont have the rear 02 sensor tuned out you will prob get a cel for it.
