hp tuners
Old Feb 5, 2013 | 11:01 PM
08balt's Avatar
hp tuners
if i buy hp tuners does it come with any base tunes in it for like a stage two
Old Feb 5, 2013 | 11:02 PM
user 72239's Avatar
no. it only allows you to tune your car but comes with no flashable tunes
Old Feb 6, 2013 | 08:33 PM
Infernokron's Avatar
Semi-correct.
The software comes with no tunes. The serial number you get with the software package gives you access to HP Tuners' tune repository on their website. There are several LSJ tunes and a listing of what the tunes are for (stock, 2.8/60's/DP, etc.).
The first thing you do is read your current tune out of the car, then you can compare the differences between that and the tunes in their repository to figure out what you need to change.
I would still highly recommend spending a good few days researching tuning before playing with your cars tune though.
Old Feb 7, 2013 | 10:13 PM
c130aviator's Avatar
repository tunes are unsecured and can screw you up if you dont know what you are looking for. I have read for weeks on tuning and still dont trust myself. Get the software for small changes like tire sizes, removing evap, editing stuff out for your build, etc. but when it comes to tuning let a pro do it. logging is what its best for if you are new to tuning.
Old Feb 8, 2013 | 01:31 AM
ThexGovenor's Avatar
Anyone try to tune without the pro version?
Old Feb 8, 2013 | 01:45 AM
Vander Nars's Avatar
I use standard verison for logging and james does the tuning, stardand works just fine for tuning
Old Feb 8, 2013 | 01:56 AM
SunburstSS's Avatar
You can still monitor AFR's from a wideband from a standard version, you just have to use a the AC output line, I did and it worked out well
Old Feb 8, 2013 | 08:14 AM
^this, and here is a writeup for lsjs
LSJ LC1 wiring into AC/EGR? non Pro VCm - HP Tuners Bulletin Board
i use standard
Old Feb 8, 2013 | 08:21 AM
user 72239's Avatar
I have the pro, I didnt know you had to wire it up with the Standard version
Old Feb 8, 2013 | 09:54 AM
mrbelvedere's Avatar
I have pro I don't like cutting into the harness unless I have to
Old Feb 8, 2013 | 11:19 AM
No cutting. Simple wire tapjust below pcm
Old Feb 8, 2013 | 11:24 AM
that is still cutting into the wiring not to mention you should run a switch to turn the wb on and off so the ac will work correctly
Old Feb 8, 2013 | 08:28 PM
Good point, just because something is in the repository doesn't mean it's correct. That being said if you compare several tunes that say, all use #60 lb/hr injectors, you should be able to figure out what needs changed.
I did recommend reading up for a good while. I researched tuning for months before tackling it on my car. Even then I didn't have a good idea what I was doing when I started. At some point your going to have to bite the bullet and start changing numbers though. In my mind why would you pay all the money for HP tuners and then pay someone else more money so they can use *their* HP tuners to tune your car? Yes, you may mess something up, but the same can be said for in-properly installing aftermarket parts.
As far as pro v.s. standard I got pro. Yes you can tap the AC line to log wide-band however as mrbelvedere mentioned, your messing with the wiring harness. Also what if you want to log in an EGT sensor or any other sensor? Pro gives you the ability to do all of this painlessly. Besides...it's just money
Old Feb 8, 2013 | 10:15 PM
I also used it to scale my 80 lb injectors. Got my car running and know enough to fix small tuning issues. Any one modding should make this their first mod.
Old Feb 9, 2013 | 12:20 AM
southal cobalt's Avatar
tuning isnt hard. theres lots of info on hpt forum & rlf. its easiest to play around with your tune when the car is stock to gain a general understanding and if you have issues when tinkering, just flash back to the stock file. and when you buy a stage kit, have zzp email you the tune file. then you dont have to deal with sending off a pcm or paying 200$ for a new one. if you look at it that way, hpt practically pays for itself.
Old Feb 9, 2013 | 12:28 AM
SunburstSS's Avatar
Pfff screw cutting the harness I just got a plug to match the AC plug all I had to do when I wanted to use it is unplug the wire from the compressor and into my own plug take less than 10 seconds and no cutting of ur original harness is needed or at the PCM
Old Feb 9, 2013 | 12:33 AM
^I was thinking of this but at the pcm instead.
Old Feb 9, 2013 | 12:42 AM
SunburstSS's Avatar
^ i know exactly whatcha mean, that works too,i personally didnt mess with the pcm harness as getting that plug was much easier for me lol. One thing is to keep in mind is that you want to turn off the ac function in hpt the fan speed vs ac voltage i believe thats what its called " dont have hpt available atm lol " as the fan will kick off annoyngligy preventing the car from being at optimal temp. And I wouldn't use the ac or the rear defroster during that session either
Old Feb 9, 2013 | 12:49 AM
noted, ive had it setup for 6 months now.
Old Feb 9, 2013 | 12:53 AM
SunburstSS's Avatar
^ I love ur car btw I always wanted a yellow Balt blacked out I guess next car lol
Old Feb 9, 2013 | 01:12 AM
thanks man, still trying to decide my next move. Enjoying her as she sits now though.
Old Feb 9, 2013 | 01:45 PM
SSlobalt's Avatar
You don't, for the LNF. Wideband is available on the ECM.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
riceburner
Mid Central
Oct 5, 2015 09:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
09SSlow
Sep 28, 2015 12:37 AM
OPCrer
Sep 27, 2015 08:11 PM
