hurst shifter wobble
I just installed the hurst the shifter and it basically works fine. The problem i have is that the shifter kinda wobbles or rotates clockwise or counter clockwise. I'm not sure but i think its the little tiny screw with the locktite on it cuz that bolt is stripped and i cant get it out so any possible advice would be great!! I did a search and couldn't find much on this problem
I know what you mean. Mine dosen't do it.. but a friends does. If you use the "correct" size wrench to put the screw in it will strip before it gets tight enough. I had to use a wrench one size larger... tap it in with a small hammer, then screw it down... to get it to work.
you need to take the shifter back out... pull the stupid set screw back off... and go down to the hardware store...
get a longer set screw... they're common parts... and won't cost more than 25 cents... put the new screw in and you should be set... the one Hurst sends is cheap.
I had the same problem that you guys are having. And after close examination between my hurst and my friends, we found out that my shifter had issues. lol basically where the set screw goes in to tighten to the shifter, it wasn't tapped all the way through. so my shifter was twisting and wobbling around. take yours out and look at it closer, it might have the same problem that mine had. i dunno just a thought a personal experience speakin here. good luck though
I don't know the size.. sorry... just take the shifter in with you and you can figure it out...
Cptnslo
Sep 24, 2015 09:32 AM
The Rookie24
Sep 20, 2015 04:33 PM
