hurst shifter wobble
Old Sep 12, 2007 | 10:11 AM
pinoypapi198369's Avatar
I just installed the hurst the shifter and it basically works fine. The problem i have is that the shifter kinda wobbles or rotates clockwise or counter clockwise. I'm not sure but i think its the little tiny screw with the locktite on it cuz that bolt is stripped and i cant get it out so any possible advice would be great!! I did a search and couldn't find much on this problem
Old Sep 12, 2007 | 10:24 AM
RaineMan's Avatar
I know what you mean. Mine dosen't do it.. but a friends does. If you use the "correct" size wrench to put the screw in it will strip before it gets tight enough. I had to use a wrench one size larger... tap it in with a small hammer, then screw it down... to get it to work.
you need to take the shifter back out... pull the stupid set screw back off... and go down to the hardware store...
get a longer set screw... they're common parts... and won't cost more than 25 cents... put the new screw in and you should be set... the one Hurst sends is cheap.
Old Sep 12, 2007 | 10:26 AM
chevyss's Avatar
I have the same exact problem with my Hurst short throw as well. Followed the directions and even tore it back apart to refine this issue; found out that set screw is stripped causing it to have that minor rotation/ wobble. Since it is locktite I could not tighten it any more; not as solid as it should be. I probably should have waited until locktite cured.
Old Sep 12, 2007 | 10:29 AM
95cam86roc's Avatar
I had the same problem that you guys are having. And after close examination between my hurst and my friends, we found out that my shifter had issues. lol basically where the set screw goes in to tighten to the shifter, it wasn't tapped all the way through. so my shifter was twisting and wobbling around. take yours out and look at it closer, it might have the same problem that mine had. i dunno just a thought a personal experience speakin here. good luck though
Old Sep 12, 2007 | 11:00 AM
good advice guys, well i know i stripped that little bolt so i hope i can get it out and replace it. Do u remember what the size was of the replacement screw u used rainman?
Old Sep 12, 2007 | 11:01 AM
an0malous's Avatar
i remember reading where someone else did this, and they bought some replacements from like home depot or something.
maybe just take it with you to a hardware store and see what they can do.
Old Sep 12, 2007 | 11:21 AM
RaineMan's Avatar
I don't know the size.. sorry... just take the shifter in with you and you can figure it out...
Old Sep 12, 2007 | 12:13 PM
ok cool, i just hope i can get it that screw out
Old Sep 12, 2007 | 12:21 PM
RaineMan's Avatar
drill it out if you have to... hopefully it won't come down to that... you could always buy a stripped bolt/screw remover... they ain't too expensive.
Old Sep 12, 2007 | 10:09 PM
well i took ur advice and hammered in my hex and tighten the bolt down and now its not really wobbling. It will budge if u use a little force but it sooo much better now and as a plus i adjusted the cables to where it feels almost perfect with every shift, thanks for the advice ++rep
Old Sep 12, 2007 | 10:13 PM
RedEcotecSS's Avatar
heh, i'm the friend. hahaha. but yeah, i still haven't tried to pull mine back out.. need to do that sometime.
Old Oct 17, 2008 | 08:18 PM
leviticus88's Avatar
What size set screw fits? So I know because I only have one car to get to home depot, thanx!
007Buff
Jun 11, 2017 03:04 PM
biniecki
Oct 25, 2015 02:23 PM
Cptnslo
Sep 24, 2015 09:32 AM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
