Hurst short throw
Old Oct 3, 2009 | 05:37 PM
defo98's Avatar
Hurst short throw
Is there a way to adjust the short throw from hurst? I got it all in and it really doesnt seem any shorter then my stock one.
Old Oct 3, 2009 | 11:59 PM
hungryhip-ccp's Avatar
yeah i didnt notice a reduce in throw AT ALL.
Old Oct 4, 2009 | 12:01 AM
ChriSS/SC's Avatar
Hurst = fail?
Old Oct 4, 2009 | 12:07 AM
CSS87915's Avatar
It is shorter not as much as u expected tho
Old Oct 4, 2009 | 12:13 AM
09turbo's Avatar
the TWM is a full 1 inch shorter... i think its better then the hurst but i cant say much i dont have one.
Old Oct 4, 2009 | 02:19 AM
Otown07's Avatar
Nah, not much shorter, and there's nothing you can do about it. But at least it won't come apart like the stocker...
Old Oct 4, 2009 | 02:37 AM
steddy2112's Avatar
Height has NOTHING TO DO WITH THE THROW
Jesus
Old Oct 4, 2009 | 02:56 AM
~Mike~'s Avatar
When has a "stocker" ever come apart? I've never heard of such a thing...
Jesus
True...unless ur shifter is 2 ft. tall. At that point, shortening the height would also shorten the throw. But we drive cobalts, not Kenworths, so that's not an issue lol
Old Oct 4, 2009 | 10:52 AM
Karlen89's Avatar
My hurst has a shorter throw than stock. shorter than stock. Juss sayin
Old Oct 4, 2009 | 10:57 AM
TurboTechRacing's Avatar
Jesus
X2, it does not mean short in HEIGHT, it is shorter in throw.... From 1st to 2nd, the "throw" reduction is around 30% or 1/3 the throw of stock.
Old Oct 4, 2009 | 11:09 AM
rollingboostedss's Avatar
I notice a difference in mine when I put it in especially with the shifts to 2nd and 4th
Old Oct 4, 2009 | 12:36 PM
09turbo's Avatar
Jesus
it actually does but nothing so big its worth doing if your just shorting it. its all in th linkages.
i just think a short shifter looks cool cuz its shorter.
like this guy said. it helps a little. nothing noticable.
only reason id go aftermaket is when my breaks. which i feel is soon cuz the shift patter is kinda loose lol
Old Oct 4, 2009 | 12:39 PM
BlackSSNick's Avatar
I hate my hurst, it twists for some reason i guess because of the set screw that comes with it isn;t big enoguh, and its hard to get into 2nd gear sometimes
i thought about putting my stock one back in, it felt more solid
Last edited by BlackSSNick; Oct 4, 2009 at 12:39 PM. Reason: Automerged Doublepost
Old Oct 5, 2009 | 12:13 PM
defo98's Avatar
yeah I have that twist in mine too. Is there a way to get rid of that?
Old Oct 5, 2009 | 12:20 PM
pmerritt's Avatar
you can easily fix that, take the screw out and clean the threads of the hole and the screw (i simply used a little alcohol) the re-apply some loctite and make sure you let it set for at least 20-30mins before driving. I actually did this in the evening and let it set overnight and i have had zero problems with it since.
Old Oct 5, 2009 | 12:30 PM
StageII07's Avatar
take it a part and tighten the set screw and put the locktyte it comes in the kit in there..it will lock it up..no more twist i have the same prb just too lazy to re do it =p
and just saying..mine is a noticably shorter..it shifty gears much quicker =] me like..
oh wait waht he said! lol
Old Oct 5, 2009 | 12:31 PM
MikeyB's Avatar
The set screw sucks on the hurst, i just drilled it out and put a bolt in and cut the head off, wont ever come out now :p
06MetallicBalt
Jul 20, 2025 08:47 PM
Cptnslo
Sep 24, 2015 09:32 AM
Dustonian131
Sep 23, 2015 08:03 PM
ashalle2
Sep 16, 2015 10:36 PM
SS_2009_TC
Sep 11, 2015 05:41 PM
