i fell victom4 ringland!
Old May 6, 2007 | 06:55 PM
NJHK's Avatar
Originally Posted by 06blackg85ss
lol... forgot about that dude in your sig adam... **** is funny
You realise that's me right? LOL
FYI: Check your voice mail
Old May 6, 2007 | 07:08 PM
R&C_rallySS's Avatar
Originally Posted by Mikey851
Too much boost = waste of money and time in our cars (Too much being more boost than your engine is willing to deal with).
I'm not saying anyone should do it but with the 10:1 pistons and customs cams GMP made a little over 300WHP. They were running a dual pass setup and tuned it for the setup.
Honestly I really think that alot of people are underestimating what a good cam setup can do when couple with other supporting mods like valve springs, good exhaust setup, P&P. I could see a LSJ making more power with these kinds of mods at 15psi than a stock setup running 21psi, if it can even keep running at all.
I agree 100%. IMO, all of those mods you mentioned running on GM Stage III would be a killer set up. I still would keep the stock 9:1
Old May 6, 2007 | 07:12 PM
06blackg85ss's Avatar
I meant the quote lol./ of course I know it's you man.
hahaha
and btw that was a very disturbing message. Forgot I shut my ringer off and just listened to it
Old May 6, 2007 | 07:30 PM
Mikey851's Avatar
Yeah, I would probably use stock compression as well just to be safe. Although I think on stage III boost you would be okay with the 10:1 but you would have to use the 100 octane rated tune and pull some timing possibly. if you were planning on even slightly getting on it.
You might as well avoid this by sticking with stock compression and using the 100 octane tune and all of it's timing to make your power. There are many ways to make power; some are more risky than others haha AKA 2.5" pulley .
Acidangel_5.0's Avatar
Originally Posted by 1fstss
i was out racing fri night and i felt a slight power loss, i at 1st thought it was heat soak on the blower so i took it easy after that. on the way home i pulled over to take a **** and on my way back to the car i noticed something on my fender, sure as **** it was oil! so i popped the hood and my dip stick was 3 inches in the air and there was oil every where! i guess thats what i get for spraying a 75 shot (actualy a little less due to low bottle pressure) ontop of a 2.7 pulley i did get a few respectable kills though before she went! a built evo with a white rabbit turbo, i put a solid 1-2 cars on him from a 40 roll and a turbo civic hatch from a 40 roll, i put train lengths on the civic! but anywho it just gives me an excuse to put the 10.5:1 compression pistons in with a new clutch and a few other goodies! just sucks that the car is down for a few weeks and im stuck driving my 11 second camaro to work
Old May 6, 2007 | 07:48 PM
1fstss's Avatar
while into the spray im running a very safe 10.3:1 give or take. i have 60lb injectors too, if you dont have 60's on any pulley smaller than a 2.8 your dumb and just asking for trouble. my tune was very conservitive, but any motor no matter what you do can only take soo much abuse. and why would you not up your compression if you can? i thought our lower ends where good to 500 whp.
Old May 6, 2007 | 08:06 PM
SS33's Avatar
^^The lower end can, but it's typically not worth the extra hassle of tuning headaches. But if you know what you're doing anything is possible, and I'm sure you could make it work.
I personally would never up the compression on a daily driven FI vehicle, as I would rather have the piece of mind that comes with a nice sock or lower compression built motor. No worries that way at all. If I re-build I want to be god damned sure I won't be pulling it apart again later.
Old May 6, 2007 | 10:14 PM
zinner's Avatar
Moderator Alumni
Dan has done some testing and AFR lower than 11.5 basically raises the EGT temps and causes piston melt down.
I am running a 2.8 and a 75 shot and about 12.0 AFR with no knock and stock timing.
Old May 6, 2007 | 10:24 PM
Mikey851's Avatar
I am running a 2.8 and a 75 shot and about 12.0 AFR and running nicely with no know and stock timing.
Well, judging by the common #4 cylinder problem and the notion that it correlates with the fact that we have a returnless sytem that has the potential to lack enough pressure to provide all that is needed, I would agree with you.
Not that the rich mix is what is causing the high EGTs but the fact that if the mix is being commanded too rich your fuel system cannot keep up. Therefore you will monitor a rich condition, however a deprived cylinder will have a lean condition therefore causing EGTs to rise.
Turbo Johnny
Feb 21, 2019 09:41 AM
soccerkid13
Jan 11, 2016 10:25 AM
shawnsseries
Sep 10, 2015 08:29 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
