I lost 10 psi????
Old Nov 15, 2008 | 01:17 PM
sicksilverss/sc's Avatar
Question I lost 10 psi????
I driving my car and all of a sudden when im flooring it im getting like 8 psi, instead of the normal 18. What could be the problem? Could it be the boost bypass valve? Help people, this is driving me nuts!!!
Old Nov 15, 2008 | 01:19 PM
BLAZIN07SS's Avatar
I'm too JDM for you
is your car driving normal? same performance? if so, might be the gauge. i know my stock one broke
Old Nov 15, 2008 | 01:22 PM
EatonTVS07's Avatar
bypass valve maybe? can you hear a leak?
Old Nov 15, 2008 | 01:23 PM
XM15's Avatar
Like Blazin said. Could you feel a difference, or were you just going by the gauge?
Could be some major belt slip. lol
Old Nov 15, 2008 | 01:25 PM
No, there is a big performance loss.
Where would i check for a leak? When i manually move the bypass valve it really doesnt sound too smooth.
Last edited by sicksilverss/sc; Nov 15, 2008 at 01:25 PM. Reason: Automerged Doublepost
Old Nov 15, 2008 | 01:28 PM
EatonTVS07's Avatar
well you'll hear it as your driving, as you wot it and it hits that 8psi you will here a boost leak up front, not hard to miss
Old Nov 15, 2008 | 01:39 PM
ssaddiction's Avatar
you still have a warranty? make the shop figure it out haha
Old Nov 15, 2008 | 01:42 PM
With all the mods i dont think that the warranty is still in effect
Old Nov 15, 2008 | 01:47 PM
EatonTVS07's Avatar
take it up and see they have to prove your mods is what caused it to happen.
my guess is the bypass valve, happened to be, clogged cat, shot o2 sensor, and stuck open bypass valve, went from 15psi to 10 and you could hear a fluttering sound like the boost was escaping
Old Nov 15, 2008 | 04:05 PM
ShortStack's Avatar
Is there a some or none at alll... 10 psi would do alot of difference..
Old Nov 15, 2008 | 04:12 PM
idunn's Avatar
any CELs?
Old Nov 22, 2008 | 04:09 PM
Why when i switch the 2 lines on the boost bypass valve i get 19 psi but when i hook it up normally i only get 9 psi. I bought a new bypass valve and put it on and it still didn't work. Does it need to be set a an exact point?
Old Nov 24, 2008 | 10:47 AM
Any Help here Guys? Pls let me know what you think! Boostless here!
ShortStack's Avatar
its probly your gauge...
Old Nov 24, 2008 | 04:22 PM
HunterKiller89's Avatar
if you know any other SS/SC's, swap blowers with them (or just the bypass valve). Really, the bypass valve is the only thing big enough to leak 10psi of boost. what kind of guages do you have?
Old Nov 24, 2008 | 04:43 PM
ShortStack's Avatar
but he isnt suffering any performance loss, which is why i think its the gauge.
Old Nov 24, 2008 | 04:47 PM
fballman1987's Avatar
he said there was a big performance loss.
Old Nov 24, 2008 | 04:51 PM
leahciM's Avatar
since when is 18 psi on an lsj normal without some crazy small pulley? maybe theres a problem right there.......
Old Nov 24, 2008 | 08:35 PM
Stihl's Avatar
Check your spark plugs and see if they are burnt out
Old Nov 24, 2008 | 09:31 PM
Iwhine's Avatar
A list of mods would be decent pulley size, belt, over sized tensioner, ect, could be many things from gasket, bypass valve, belt slip, mods be a good place to start to know what would and probably failed
Old Nov 24, 2008 | 09:32 PM
Steven Flit's Avatar
Wow people...
Just do a compression check already
Old Nov 25, 2008 | 09:40 AM
ShortStack's Avatar
Old Nov 25, 2008 | 10:42 AM
rnjmur's Avatar
Could be the boost control solenoid.
Old Nov 25, 2008 | 10:56 AM
Bika's Avatar
Fail Less.
Check your heat exchanger pump. if its not moving fluid, you will heatsoak rapidly and the ecu will cut boost by like half.
Old Nov 25, 2008 | 02:19 PM
I disconnected the vacuum line off of the bypass valve that connects to the electronic solenoid and plugged the hose with a bolt and i have all my boost back. The valve is working with the one hose disconnected, kind of like a blow off valve. So the problem is the electronic solenid??? I looked at my intercool fluid and i couldnt see it flowing so i added some and hit the pump with a ratchet and now its working. When i disconnected the plug off of the electronic solenoid before iwas only getting like 4 psi. So do you think the computer is ok and i should just have chevy change the solenoid? I will see if they can do it under warranty? My mods shouldn't matter right?
My mods are Injen intane, SLP shorty headers, XTC catless downpipe, SLP exhaust, ford motorsport 42# injectors, pulley boys 2.8 pulley, aem meth injection, cobra front mount heat exchanger, and all my tuning is done by TUNETIMEPERFORMANCE.
