I need help
Old Aug 31, 2008 | 05:34 AM
ls1fbody's Avatar
Haz l33t wheelz.
cool man, good luck with this!
Old Aug 31, 2008 | 06:10 AM
Steven Flit's Avatar
Originally Posted by ikeryder13
yeah i was....
shell gas... but i always go there
******* crazy dude.. .I was at a shell too when it happened.. it may very well be a bad batch of gas.
Old Aug 31, 2008 | 06:12 AM
ls1fbody's Avatar
Haz l33t wheelz.
that is weird. i've never had a problem with shell, they're on the top tier list, but i guess anything is possible.
Old Aug 31, 2008 | 10:55 AM
simmonsnick's Avatar
plus it was weird guys like when i thought it stalled i tryed to pop the clutch cuz i was still moving and my rpms jumped and then dropped and thats when it finally stalled
yeah i will... i am just worried they will say something about my intake
i have stulled befroe and you have to turn the key all the way off and back to run or it will not start. i dont know why youll have to ask gm on that one prob safety thing but even if you stop the car and try to start and you didnt turn the key to off yet it will not start you have to turn the key OFF to reset pcm maybe?
Old Aug 31, 2008 | 11:01 AM
EatonTVS07's Avatar
check your boost bypass valve, will your car boost past 10 psi?
Old Aug 31, 2008 | 12:36 PM
ikeryder13's Avatar
yeah... my supercharger is making a noise like a turbo spooling.... It sounds weird.... but its running fine.... when i turned my vehicle on this morning the CEL was gone... Plus autozone doesnt to the code check anymore so i am pretty sure it was a misfire... But i dont know why its making that noise
Old Aug 31, 2008 | 12:42 PM
EatonTVS07's Avatar
when i got my car the cat clogged up and blew the bypass valve open so i could only boost to 10 psi and it was making a weird sound
Old Aug 31, 2008 | 12:48 PM
ikeryder13's Avatar
no my cat sounds fine....
my sxhaust does sound a lil more quiet but that could be just cuz my supercharger sounds so loud now
Last edited by ikeryder13; Aug 31, 2008 at 12:48 PM. Reason: Automerged Doublepost
Old Aug 31, 2008 | 12:50 PM
brett5's Avatar
does it sound like air or a high pitch scraping
EatonTVS07's Avatar
mine got alot quiter when the cat was plugged, but anyways i'm just saying maybe if your bypass valve is stuck open it might be that sound
Old Aug 31, 2008 | 12:52 PM
  #36
ikeryder13's Avatar
like high air
**** i just got this cat... its my 3rd one
Last edited by ikeryder13; Aug 31, 2008 at 12:52 PM. Reason: Automerged Doublepost
Old Aug 31, 2008 | 12:55 PM
  #37
EatonTVS07's Avatar
no ****, just go catless or high flow
Old Aug 31, 2008 | 01:04 PM
  #38
ikeryder13's Avatar
yeah i know
but why would it sound like more air???
Last edited by ikeryder13; Aug 31, 2008 at 01:04 PM. Reason: Automerged Doublepost
Old Aug 31, 2008 | 01:05 PM
  #39
EatonTVS07's Avatar
air escaping through the open bypass valve
Old Aug 31, 2008 | 01:06 PM
  #40
ikeryder13's Avatar
can u look and tell anything?
Old Aug 31, 2008 | 01:08 PM
  #41
EatonTVS07's Avatar
not sure if you'll be able to but i could tell when i tried to full throttle it it would only go to 10psi and i could hear it venting off
Old Aug 31, 2008 | 01:09 PM
  #42
ikeryder13's Avatar
well i will just have to take it to the dealer i guess
Old Aug 31, 2008 | 01:11 PM
  #43
EatonTVS07's Avatar
i would every once in awhile i'd get a check engine light and it would turn off
Old Aug 31, 2008 | 01:13 PM
  #44
ikeryder13's Avatar
this is my first one
Old Aug 31, 2008 | 01:15 PM
  #45
EatonTVS07's Avatar
i'd just say take it to gm
Old Aug 31, 2008 | 01:16 PM
  #46
ikeryder13's Avatar
yeah does anyone know if the dealer is open monday?
Old Aug 31, 2008 | 01:17 PM
  #47
EatonTVS07's Avatar
doubt it
Old Aug 31, 2008 | 01:20 PM
  #48
ikeryder13's Avatar
gay....
Old Aug 31, 2008 | 01:22 PM
  #49
Greased's Avatar
Originally Posted by ls1fbody
your intake shouldn't cause that.
take it in, and if they say anything about the intake, make them prove it.
it could be a super bad maf sensor needs to be cleaned in which case it is caused by an aftermarket intake and they WILL charge him.
Old Aug 31, 2008 | 01:23 PM
  #50
ls1fbody's Avatar
Haz l33t wheelz.
GL man, if i were you, i'd pull off the intake and have a buddy look and see if the bypass is stuck open, but it's be loud as **** for him haha
i was thinking that too, but damn, it sure took a serious **** really quick.
