i need a little help
Old Sep 7, 2008 | 10:03 AM
brett5's Avatar
ok heres the deal i had the meth kit on and running great for about a month with the check valve and everything...everything worked great....now the past few days i've been noticing that when i drive for like 5 min and everytime i try to give WOT whether at 3k or 5k it seems to choke for a split second then continue it normal run untill i let off the gas and shift.....it does it whether the clutch was engaged or not so i don't think its that..so i unkooked the meth and went for a run...great problem gone....but now wtf.. do i just keep turning the boost up on the meth till it starts working right again???or is there anything else wrong
and i have a 3g nozzle...i'm thinking i may just need to get a tune.
damn..cause there is no one in reading pa that tunes unless you guys know of anyone within like a half hour
Old Sep 7, 2008 | 01:47 PM
thatotherguy's Avatar
spark plugs, MAF sensor or Throttle body needs to be cleaned! Maybe all 3
