I need your help with installation!
i bought one of those cheap performance chips for my cobalt but i need to find the O2 sensor and air intake temperature sensor. if and one can help me with directions to a website or know where please help me.
Open your hood. Look to the right of your block, you will see a bundle of wires about 18" down. take out your knife, scissor, razor blade. Slice the the "performance" chip in half, throw it in the garbage, close your hood and enjoy the increased performance of your vehicle over the decrease you would have seen with the chip in place.
If you must know... the MAF in the SS/SC (since you posted in the 2.0 section) is down by the air filter... you'll need to jack the car up and take the drivers side tire off... then take out all the fasteners for the front part of the wheel-well liner... then you can access the airbox and MAF.
No... bad cobalt, stop throwing codes, no put that axle shaft back in, awww cobalt you're supposed to go on the paper not on the garage floor. Cobalt do you want to go back to the dealer, im warning you... Don't make me put nitrous on you.
You would get better performance enhancement by washing your car.
Albeit, it is a small weight reduction, but would have better effects on performance me-thinks.
In the event that you were serious and you really are trying to install this on your car,
see my first post!
see my first post!
dont do it. Your car will blow up in a firey explosion and you will be burned alive because the chip will cause your seat belt to malfunction. Those chips disable the seat belts in the car.... dont do it...........
Sorry Rizo, but they are right, it is definately the wrong "Performance" mod to do to the car. Not only will you run either extremely rich, or extremely lean, but as soon as the dealer sees that you spliced into your wire harness....
WARRANTY
WARRANTY
Delta coupe
Sep 30, 2015 08:11 AM
