i think i found a 6speed for our cars
after some reasearch i think i have found a 6 speed for our cars it is in a 2007 saab 9-3 from what i understand they are turbo but they use the same block as us so in theory it should bolt rite up let me know what you all think
Rattlesnake Race Shop
F40
It's been done... it works... it's not a direct bolt up.
With the Saab Bellhousing, it is a direct bolt-on. With the Pontiac Bellhousing, it is not a direct bolt-on. I also know that the Pontiac F40 has a different spline count than the F35 that we use. I'm not sure if the Saab is the same or not though, but I'd imagine it shares the same spline count as the Pontiac F40... meaning you'd need a different clutch.
I wasn't talking about the bellhousing... it's well known that the F40 is a direct bolt on to the engine... but it's the rest of the stuff that needs some finesse.
The clutch / flywheel is the biggest issue. Unless you want to go with Spec, you'd have to get a flywheel custom ground, and your choice of clutch. As well, the cables need a bit of custom modding.... and then there is putting new connectors on some of the trans sensor plugs.
Just little things, that don't make it a true 'bolt-in' item.
we have a 5 speed with two overdrives...
http://www.fastfieros.com/NEW_manual...ion_ratios.htm
