i think i found a 6speed for our cars
Old 05-13-2010, 12:03 AM
edmbaltss's Avatar
after some reasearch i think i have found a 6 speed for our cars it is in a 2007 saab 9-3 from what i understand they are turbo but they use the same block as us so in theory it should bolt rite up let me know what you all think
Old 05-13-2010, 12:08 AM
BlackJackSS's Avatar
i think you should buy one and write a review on it. sound good?
Old 05-13-2010, 12:11 AM
PsshPlzz's Avatar
quaife makes a 6spd gear set
Old 05-13-2010, 12:13 AM
Haz l33t wheelz.
ls1fbody's Avatar
and the F60 with a bellhousing swap is in the testing stages.
Old 05-13-2010, 11:16 PM
edmbaltss's Avatar
bump and more info folks
Old 05-13-2010, 11:23 PM
Rattlesnake Race Shop
USMCFieldMP's Avatar
I wouldn't say you found it... many of us have looked at it before... I considered the swap once before. IIRC, the spline count on the Input shaft is different from that of the F35... but you'd just need to get a custom clutch made, or buy a clutch made for the 9-3.
F40
Old 05-13-2010, 11:24 PM
09turbo's Avatar
interesting....
Old 05-14-2010, 04:47 AM
Maxim_X's Avatar
It sounds like a good idea. But, I would imagine the big power guys would be wary of going with a transmission with questionable strength.
Old 05-14-2010, 05:08 AM
buckshot3448's Avatar
but so not worth the price
Old 05-14-2010, 10:16 AM
Lifter's Avatar
x2
Old 05-14-2010, 11:01 AM
Jrhdpaintball's Avatar
subd
Old 05-14-2010, 11:05 AM
Omega_5's Avatar
Welcome to two years ago.
It's been done... it works... it's not a direct bolt up.
Old 05-14-2010, 11:15 AM
steddy2112's Avatar
Why is everyone obsessed with a 6 speed that has two overdrives?
Old 05-14-2010, 11:23 AM
Omega_5's Avatar
Originally Posted by steddy2112
Why is everyone obsessed with a 6 speed that has two close ratio overdrives?
Fixed that up for you....
And I don't know why. It just makes the first three gears that much more useless.
Old 05-14-2010, 11:24 AM
TurboTechRacing's Avatar
Yup, we have sold 5-6 over the last couple years.
Old 05-14-2010, 02:32 PM
The F40 is rated for more torque than the F35.
With the Saab Bellhousing, it is a direct bolt-on. With the Pontiac Bellhousing, it is not a direct bolt-on. I also know that the Pontiac F40 has a different spline count than the F35 that we use. I'm not sure if the Saab is the same or not though, but I'd imagine it shares the same spline count as the Pontiac F40... meaning you'd need a different clutch.
Old 05-14-2010, 02:36 PM
Omega_5's Avatar
I wasn't talking about the bellhousing... it's well known that the F40 is a direct bolt on to the engine... but it's the rest of the stuff that needs some finesse.
Old 05-14-2010, 03:06 PM
Okay... I get what you're saying now. I thought you were implying that it didn't bolt-on to the car directly.
Old 05-14-2010, 03:09 PM
Omega_5's Avatar
Oh, yeah... not what I meant at all.
The clutch / flywheel is the biggest issue. Unless you want to go with Spec, you'd have to get a flywheel custom ground, and your choice of clutch. As well, the cables need a bit of custom modding.... and then there is putting new connectors on some of the trans sensor plugs.
Just little things, that don't make it a true 'bolt-in' item.
Old 05-14-2010, 03:55 PM
09turbo's Avatar
we have a 5 speed with two overdrives...
http://www.fastfieros.com/NEW_manual...ion_ratios.htm
Old 05-14-2010, 03:58 PM
phillips01's Avatar
i got a 6 speed ls1 z28 its my wifes/to many gears errr/every time i drive it ,i think man im always shifting gezz.
Old 05-14-2010, 04:00 PM
09turbo's Avatar
when i drive my friends GTO it feels the same way
Old 05-14-2010, 10:18 PM
Jn2
Jn2's Avatar
would be cool, i would prefer it for my 2.2, but probably wouldnt work for me as easy as you guys, and what trans sensors are you talking about? i dropped my tranny when i did the clutch only saw 1 back up switch...maybe the f35 has more than the f23
Old 05-14-2010, 11:05 PM
F35 has 2, iirc. Reverse and Speed Sensor. I think the person that I know doing the swap said that the sensors on his Pontiac F40 w/ Saab Belhousing are the same as on his LSJ's F35.
Old 05-15-2010, 09:45 AM
Maxim_X's Avatar
It may be rated for more but the F35 clearly performs beyond it rating. I'm not saying that the f40 wouldn't hold up, I'm just saying it would suck to swap and have a glass transmission.
Quick Reply: i think i found a 6speed for our cars
