I think I might have a problem?
Old Jul 7, 2007 | 11:48 AM
CobaltSS313's Avatar
Originally Posted by spike
i would say most likely not yet.....check ur intake manifold gasket mine was causing oil 2 be sucked in.......how is ur car running?
is it smoking?
no not that i noticed, i usually go out with more than 1 person when i drive around so im sure someone would have told me. I'm running rich but that just black smoke not white smoke. as far as checking my intake manifold gasket, do you me check and make sure it isnt damaged? it seemed fine to me when i took my intake manifold off. my car seems to be running fine its not doing anything out of the ordinary otherthan running rich.
Old Jul 7, 2007 | 03:12 PM
blueta's Avatar
Take off the line that goes from the vavle cover to the black intake tube. If you stick a q tip in there and it comes out black you just found your problem. Do this before you get all worked up. If you do pull out oil from that line simply throw a catch can in that line and you'll get less going into your intake.
Old Jul 8, 2007 | 01:32 PM
ok i understand now, ill do the q-tip thing and then go from there. Thanks for the help.
Old Jul 8, 2007 | 01:47 PM
Brian MP5T's Avatar
Originally Posted by Letigious
That truck they tested was a v8...meaning it was either a 4.8, 5.3, or 6.0 or larger 2.0 *2.5 = 5.0L of effective displacement. I dont know what ur car is making power wise but ill assume 300ish. That is what most v8s make.
You must extremely over oil ur filter then to get it to come off.
I trust actual testing more then claims
It's not that, I know that my air filter is on the small side... It lacks surface area.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
