I want cams! but who has the best ones?
Old Jul 17, 2008 | 08:59 AM
ifknrock09's Avatar
i am wondering who has the best cams and the still be relatively cheap. i'd like to stay around the $500- $600 range. part numbers would be awesome. i'm at work and posted this from my phone so can't look up the numbers and what not from my phone due to me being at work. thanks
Old Jul 17, 2008 | 09:01 AM
IROCZ0r's Avatar
i have also been looking in to different options and different cams - i would very much like it if someone could post their particular impressions of certain cams/valvetrain setups.
thanks!
Altiery54's Avatar
gmr FTW
Old Jul 17, 2008 | 09:03 AM
lsjwannabe's Avatar
When you upgrade the cams you have to upgrade your valvetrian as well. It will be a little more than you want not to crazy.
Old Jul 17, 2008 | 09:17 AM
ifknrock09's Avatar
well i'm willing to spend money on the proper valve train. but just don't want to spend a ton of money on cams.
Old Jul 17, 2008 | 09:20 AM
EdCobaltSS's Avatar
Buy the GMRacing camshaft blanks, and send them out for a custom grind at Flowtechnicsonline.com
06black's Avatar
do some research then.
find a cam with the appropriate lift needed to support your power goals, with an effective rev range that you like.
Old Jul 17, 2008 | 10:12 AM
Gabi's Avatar
i got the jbp stg 2 cams and jbp valve springs from some one here for a very good price you dont have to change anything else with does as i know.
i havent install them yet
Old Jul 17, 2008 | 10:26 AM
ralliartist's Avatar
jbp cams don't have a sensor that you need. you will have some problems. If your are an ss/sc.
Old Jul 17, 2008 | 10:30 AM
black06ss's Avatar
what kind of problems and has someone been able to overcome them?
Old Jul 17, 2008 | 10:32 AM
I could have sworn it was already said that the jbp cams are for the 2.2 ecotecs and that if you put them on the ss/sc, you will be missing a cam sensor. Someone else can elaborate if they want. That's about all I know. I'm not going with cams anytime soon.
Old Jul 17, 2008 | 10:35 AM
Gabi's Avatar
jpb cams are sotcks cams regrinds
at least that they told
i think you can use the sensor
Old Jul 17, 2008 | 11:04 AM
SilverSurferSS/SC's Avatar
The comp cam are the ones that are for the 2.2's, and if an ss/sc uses them, they lose the cam sensor from what I understand. But it just makes it hard to start the car sometimes. Like instead of having to crank over once or twice to start, it may take 5-10 times. From what I have heard.
Old Jul 17, 2008 | 11:08 AM
ColeJJones's Avatar
Bannned
so is GMR cams better the JBP tri-flows?????
Old Jul 17, 2008 | 11:09 AM
Altiery54's Avatar
Old Jul 17, 2008 | 11:10 AM
IROCZ0r's Avatar
the only "sensor" i know of that would stop a car from starting would be a crank position sensor, and that's built into the head, and would notice a dot ground into the cam. is it really that hard to fix?
also, these blank cams, would they be compatable? i don't like the idea of a regrind.
Old Jul 17, 2008 | 11:20 AM
memphisr24's Avatar
NOTE: GMR cams are blanks....hence you have to send them out to be ground...so depending on what you get ground, you could end up with a realy crumby cam for your application if you have no idea what to get (but mostly the company that's grinding them will steer you in the right direction and give you a lot of options)
They are our cams, but blank. And they would not be "regrind" since they are blank...They are fresh and you can put any grind on them that you please. Hope that helps
Edit: Wait a second...am I wrong? <---serious question
Last edited by memphisr24; Jul 17, 2008 at 11:25 AM. Reason: Automerged Doublepost
Old Jul 17, 2008 | 11:24 AM
06black's Avatar
if you have an lsj your stuck with two options.
re-grind the stockers or run the car with no CPS and be forced to crank the car over for long periods of time each time you want to start it. due to having to fault out the system each and every time.
blanks, comp, ect all lack the needed key way in the cam.
company's that have tried to company the gm cam often get the key way located incorrectly and it throws CPS codes all day.
easy there killer.
GM-R sells a set of cams for the LSJ.
direct bolt in.
Old Jul 17, 2008 | 11:35 AM
Area47's Avatar
Rent me! per hour
gmr cams are blank?
****. then hows my car run wth them?
turbo. 272.
blower. gmr
Old Jul 17, 2008 | 11:40 AM
lsjwannabe's Avatar
Get a tvs its like having cams but more fun
Old Jul 17, 2008 | 11:50 AM
quadracer0387's Avatar
but TVS + GMR would be nice also
Old Jul 17, 2008 | 12:31 PM
trialskid's Avatar
where can you buy gmr cams?
Old Jul 17, 2008 | 12:38 PM
Omega_5's Avatar
Sold out now...
Rebel mentioned that they may be able to get a few sets made though their GM contact... but I wouldn't hold out for it.
Old Jul 17, 2008 | 12:39 PM
Altiery54's Avatar
umm out of area47's car or the few others who have them i think theres 10ppl
Old Jul 17, 2008 | 12:44 PM
Originally Posted by Omega_5
Sold out now...
HHAHAHAHAHAHHA, they would have to take donations first to get the R&D going for the cam regrind. Then, instead of doing the math and figuring out the specs that they would sell, they would just wing it and when they end up selling cams that don't have the right key hole and the grinds are all wrong, you would just be **** out of money and no cams cause you had to send them your stock ones to be regrinds. lol.
