IAT and IAT2...the official thread.
Old Jan 3, 2008 | 01:21 PM
Area47's Avatar
Rent me! per hour
air in the lines will cause irratic temps as well.
the pump control is under trq mngmnt>supercharger. the main screen in the lower left hand corner. it's under ert i believe. factory is set to 10 seconds. mine is set to when the key hits the run postion. IE 0
Old Jan 3, 2008 | 01:23 PM
Kaisoboy's Avatar
Originally Posted by Rangerondubz
Seriously, check the connection you will have to take it off to do it easily(only 2 bolts) and just hold it in your hand and plug it in, you will know if it comes on b/c it will jerk in your hand
I only paid $20 bucks for my Cobra one off of one of my friends so it shouldnt be that hard for you to find one.
That's something I will have to do on the weekend to check. Another way would be to get the car up to operating temp and open the filler tube and see if the coolant is circulation due to turbulance. (Fluid Mechanics 101) haha
Old Jan 3, 2008 | 01:25 PM
Rangerondubz's Avatar
Gotcha, and thanks again man. I would you go about bleeding the system? I take the plug off the top of the stock H/E?
Kaisoboy's Avatar
I will have to take a look at that tonight to see what mine is set to. So with the factory setting is that 10 seconds after the car is running?
Old Jan 3, 2008 | 01:26 PM
Area47's Avatar
Rent me! per hour
just open the cap, and let it run for a while, fill it up as needed
yulp
Old Jan 3, 2008 | 01:27 PM
Kaisoboy's Avatar
The pump (cobra) only cost you 20 bucks if I need a new one?
Old Jan 3, 2008 | 01:36 PM
an0malous's Avatar
Hi Anom
So this morning on the way to work I logged both IAT and IAT2. My IAT was hovering around 30*F @ 18*F ambient and my IAT2 by the time I got to work was 100*F @ 18*F ambient.
This morning was fairly easy going traffic. I am basically on the Deerfoot most of the time. I was running about 100km/hr (60 mil/hr) for a good 20 minutes no stop and go trafic at 83*C (181*F) operating temp. Once I got off the freeway I only had to stop at 4 lights and only waited at them at most 1 to 4 minutes.
cheers
__________________
yup something is definately wrong.
at 100km/h in 18* ambient temps, you should be alot cooler.
Old Jan 3, 2008 | 01:42 PM
Kaisoboy's Avatar
According to our prior discussions I believe your right. Thats why I was thinking maybe the pump is gone and possibly why I may be losing coolant.
Old Jan 3, 2008 | 02:03 PM
an0malous's Avatar
you can tell if the pump is working just by opening the cap.
you should see the coolant bubbling and gurgling by.
Old Jan 3, 2008 | 02:10 PM
M-Dub's Avatar
Plus turn it on and leave it run for a bit.... you can hear it pump...
Or as Area47 has mine set at the "RUN" position I can hear it with my car off!
Old Jan 3, 2008 | 02:59 PM
  #36
Kaisoboy's Avatar
Well I just took it for a good run. Again my IAT2 - 120*F at operating temp. I opened the IC cap and took a look and from what I can see the pump was not moving the fluid. (ie: no turbulance) So I believe either the pump is gone or maybe the fuse is hooped. Is there a fuse for the IC pump. Or maybe when they fixed my shifter cable pin under the Fuse box on Jan 3/2008 they did not put the fuse back in properly or maybe they nocked the fuse and it is not siting properly in the fuse box.
Any insite to this theory.
Old Jan 3, 2008 | 06:32 PM
  #37
stonny9's Avatar
my iat1 is about 2-5 deg above outside and iat2 runs 20-30 deg above iat1 when cruising around. I did 2 back 2 back 2.5 mile top speed runs on new years when it was 65 deg and after the second run my iat2 was 118 was cruising and started to quickly drop. I'll do a vid tomorrow on the way to work and post it up in this thread for all to watch.
edit: I usually drop 2 20 above on the iat2 when cruising for a few miles.
edit2: "cruising" for me is 5+ miles on the highway at a steady speed
edit3: I have no cooling mods just a stock pullied car with intake, header,downpipe
Old Jan 3, 2008 | 11:14 PM
  #38
Kaisoboy's Avatar
Talking
Do you have any cooling mods? I would love to see the vid.
Thanks bud.
Old Jan 3, 2008 | 11:20 PM
  #39
LopsidedJester's Avatar
i believe there is a fuse labelled on the box as Aftercooler or Aftercooler Pump in the fuse box that is for that pump. Also, check the wire connection to the pump, could be loose maybe.
Old Jan 3, 2008 | 11:32 PM
  #40
Darkmanx's Avatar
crazy ass im staying away from you when driving, your in my top 3 worse drivers list
Old Jan 3, 2008 | 11:43 PM
  #41
Kaisoboy's Avatar
Yah, I checked the fuses and they are all seated properly. I also pulled into my old work and took a look under the car at the pump and both myself and my old boss confirmed the pump is not working or seems like it is not working (No turbulence in the filler tube). I wiggled the wires and pushed the connector in to make sure it was seated. I did not disconnect the wires to se if the connections were dirty though. I just put a bid in on a Bosch cobra pump. I will check my pump on the weekend when I have time to make sure the pump is the problem. If it is at least I will have a pump on the way and if it isn't well I will have one on hand just in case. i would have it looked at under warranty but I just don't have the time to leave my car at a dealership when I could fix it myself.
For what I have read after doing a search on intercooler pumps on our site I have all the same simptms others speak about and it all points to a worn out pump.
Old Jan 3, 2008 | 11:47 PM
  #42
stonny9's Avatar
Thanks bud.
Old Jan 3, 2008 | 11:51 PM
  #43
an0malous's Avatar
thank god for aeroforce interceptors huh?
Old Jan 3, 2008 | 11:53 PM
  #44
Kaisoboy's Avatar
My IAt1 was running at 30*F (-1*C) the ambient temp was -1*C (30*F) all day here. My IAT2 was at 122-130*F so there is a huge difference and everyone says the difference between the two while say cruising at 100km/hr should only be 20-30* difference.
Old Jan 3, 2008 | 11:55 PM
  #45
an0malous's Avatar
you know this already im sure.....but be gentle with her until you get it fixed
with no cooling, that IAT2 will go through the roof if you romp on it.
Old Jan 3, 2008 | 11:58 PM
  #46
ItalianJoe1's Avatar
Like mine does now... I've seen 220 plus.
Old Jan 3, 2008 | 11:59 PM
  #47
an0malous's Avatar
im stunned you still have pistons lol.
i dont like my car going past 150.
Old Jan 4, 2008 | 12:07 AM
  #48
stonny9's Avatar
nitrous is a cooling mod.
  #49
Darkmanx's Avatar
Defective hpt. borrow stonny interceptor and check again.
Old Jan 4, 2008 | 12:11 AM
  #50
Actually I want to do that. You gonna be at Towers tomorrow Stonny?
