IAT Sensor #2
Old Jul 1, 2008 | 12:39 AM
shadowfaxss's Avatar
IAT Sensor #2
Could someone explain where the IAT2 sensor is or take a pic. Have two codes P0098 IAT Temp Sensor 2 circuit high voltage. P0480 Cooling fan relay 1 Control Circuit PCM/ECM.
Old Jul 1, 2008 | 12:46 AM
Joeyavhu's Avatar
Those are weird codes. Try unplugging the PCM for about a minute and then re-plugging it back in. If they still come up as codes, then you might want to look into it more.
Old Jul 1, 2008 | 02:42 PM
rnjmur's Avatar
When looking at the motor under the hood, the IAT2 sensor is on the top left (passenger side) corner of the intake manifold. It is also the MAP sensor.
Did you do anything recently that may have caused the codes? What happened or what were you doing when the CEL came on?
Old Jul 2, 2008 | 02:06 PM
I found the problem......connector was not tight. Snapped into place and everything is ok.
Old Jul 2, 2008 | 02:13 PM
Area47's Avatar
Rent me! per hour
all else fails. wiggle it.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
jmelton327
Sep 26, 2015 10:04 PM
Knightwolf
Sep 12, 2015 11:02 AM
