Iat2
Old Mar 23, 2010 | 04:57 PM
BumbleBee's Avatar
Iat2
Well I had the stu mod for a while now and was not seeing good temperatures(130-140) on a warm day just daily driving. I assume it was air in the lines but I tried many times to get all the air out. So i switched back to stock and now on a warm days im seeing 90's - 108, just driving not getting on it. I feel like I can get better temps still with a different setup. Anyone have other options for IAT2 temps other than dual pass, and heat exchanger, like a new kind of coolant tank or something?
Old Mar 23, 2010 | 05:11 PM
ralliartist's Avatar
did you run a bleeder line from the top of your stock heat exchanger to the tank? be sure to put a restrictor in it.
Just wondering. That would allow it to constantly bleed the system of air.
Old Mar 23, 2010 | 05:16 PM
YzRider452's Avatar
I have a setup now to make the option B kit into a flow through. It works BEAUTIFULLY. Its now on 2 cars, mine and my buddy Chris. He saw an awesome drop in iat2s over the option b kit.
Old Mar 23, 2010 | 05:29 PM
basically what I've ran since the beginning.
dragonkingg5's Avatar
Heard by reading etc that option b doesn't do much at all. Dual pass works and stronger h/e works. I guess something like the zzp s3 h/e. If you really want good temps, probably just got with meth and some other cooling mods to help sustain the temp
Old Mar 23, 2010 | 05:34 PM
Durtyss's Avatar
Well yz show some pics plz.
Old Mar 23, 2010 | 05:35 PM
BumbleBee's Avatar
could you explain a little more.
jimbos'ss's Avatar
this place works in cycles, the wheel is reinvented bi annually
Old Mar 23, 2010 | 05:37 PM
It gets quite annoying actually.
Old Mar 23, 2010 | 05:40 PM
BumbleBee's Avatar
then go somewhere else to lurk forums.
post some pics of your setup people
slowswap's Avatar
Second.
Old Mar 23, 2010 | 05:56 PM
you think all I do is lurk? lmao. Guess you don't see the running threads down in the racing section and the fact that I actually have a cobalt still. I constantly answer questions/help people in pm's, and I still communicate with a bunch of friends through this site.
This site is in need of a revamp to be honest. Yet one it will never get.
Old Mar 23, 2010 | 06:11 PM
BumbleBee's Avatar
You misunderstood, I said you are lurking my thread. Not that you don't help people EVER. I kinda phrased it incorrectly
But this thread is not about...how annoying it is to answer already answered or talked about topics. It is a cobalt only site so you will get a lot of the same stuff. I have searched and nothing came up answering my questions. So......
I would like to see pics of setups.
Old Mar 24, 2010 | 08:31 AM
I'll search my photobucket tonight. I'm on the other side of the world from my cobalt, so it's not like I can go out and snap some snazzy pics for you. But I'm pretty sure I have pics on my photobucket.
Old Mar 24, 2010 | 08:39 AM
freakta's Avatar
bigger exchangers work great, turn the pump on all the time, make it a single pass, port it out, get the mani and run tons of meth, make an air to air. you have tons of options
Old Mar 24, 2010 | 08:45 AM
Staged07SS's Avatar
Administrator
Administrator
Option B constantly bleeds the system, and makes the cooling system more efficient. I have run the Option B setup for over a year now, and seen great results from it. The people who say it doesn't work are the ones who installed it wrong. You would be surprised how many people mess up the simple installation.
Old Mar 24, 2010 | 04:40 PM
YzRider452's Avatar
Option B is a reservoir that keeps the coolant full in the system. All i did was drill/ tap the otion b tank, add a bung. Plastic weld it in. Run the hoses slightly different. Ill take a pic of my set up, but my ***** dirty. Gimme a minute.
Notice how the Filler neck is gone.
Last edited by YzRider452; Mar 24, 2010 at 04:40 PM. Reason: Automerged Doublepost
Old Mar 24, 2010 | 04:47 PM
This is before I cleaned it up with a new tank and all. But you get the point. These were the DIY stages. LOL, so ghetto.
Old Mar 24, 2010 | 05:30 PM
insylem's Avatar
What about attaching blocks of dry ice infront of the innercooler's ram air ?
Old Mar 25, 2010 | 11:29 AM
damn i cant think of it right now but there is a company Vulcan i think that makes a metal option b tank big enough so instead of two coolant tanks, its only one and says you can put ice in there.
searched for 10 mins and gave up... there is one though that says u can put ice in and big enough so u can run one tank. ottp has a one but not much info on their site.
another question, where are you seeing temps at 140 and stuff. is this for the manifold temp? on my DIC, at the end it tells coolant temp. mine says like 190... im probably think of something totally diff than iat. thinking about abbrevations, iat mean Intake Air Temps??
Old Mar 25, 2010 | 11:37 AM
Staged07SS's Avatar
Administrator
Administrator
That's your coolant temp .... IAT2 = Intake Air Temp 2 (Air temp after the supercharger).
Zach06CobaltSC
Jun 22, 2008 06:00 PM
Scoot05RedSS
Mar 31, 2008 10:54 PM
LopsidedJester
Sep 1, 2007 10:54 PM
Blown 4-banger
Oct 24, 2006 06:25 PM
