iat2 numbers.. need help and input
so today they were reading 16x and 159. out side temp was 108 here in tx lol but still they never really went down. i got a dual pass and ottp h.e . could there be something wrong on the dual pass they way the hoses were ran? or is it the pump? anyone with any suggestions and help ill apreciate it thanks.
If you were cruising around those temps are high, but if you were doing hard pulls those temps are average or low
The rule of thumb I use is if your cruising around your iat2's should be roughly 20-30 degrees above ambient or iat1. If your doing a hard pull then it varies depending on your mods and car etc.
.The rule of thumb I use is if your cruising around your iat2's should be roughly 20-30 degrees above ambient or iat1. If your doing a hard pull then it varies depending on your mods and car etc.
well if we round the numbers up it was 110 outside, which means your iat1's could have been 120 you should have been seeing about 140-150 iat2's while cruising. But considering it was SO hot outside the temps could vary a few im sure.
When it cools down outside to like a 70 or 80 degree night, check your iat2's while cruising then. ALSO just as an fyi if your cruising at -15 or -20 vac your iat2's are going to be higher then if you were driving at 0 vac.
Rico when i do a pull my iat2 hit over 200 now im pretty sure my intercooller pump is bye bye and crusing is around 150-170 when it used to be always around 140
welcome to the club
and no money to fix it
Gotta love this years weather
welcome to the club
and no money to fix itGotta love this years weather
turned the car on and see bit of coolant but if i tilt the filler so the right side of it is a lil bit up in the air all the coolant goes back and nothing goes up or tried to go by. idk if that helps to determine if its flowing or not. doesent the thermostat have to go on at a certain temp for the pump to go on? or does it automatically goes on?
just do a little searching
the reserve by the fuses is engine coolant, not intercooler. I would just look for turbulance in the fluid while the car is on. Thinking twice about it, I think that your 160* is high, I got into the mid 140s today and i was in the city stopping at lights, not cruising at 65 or 70...
i dont think you have to much to worry about im in louisiana and mine arent quite that high there runnin about 140 or so give or take but the tem here has been 100 to so i think youre fine if youre at 108 just my opionion
