IAT's
Old Feb 20, 2011 | 05:14 PM
Tarheel62592's Avatar
IAT's
What should my IAT's be when im in idling, cruising, and after a pull? I have an OTTP heat exchager, dual pass and an Option B.
Old Feb 20, 2011 | 05:23 PM
05Slowline's Avatar
depends on pulley and it'll be different for everyone, way too many variables
Old Feb 20, 2011 | 05:25 PM
GMS2 pulley, and mine are at like 130 just cruising around...i feel like thats way too high
falke401's Avatar
Many people say about 20 degrees above ambient temp. Mine usually runs about 25-30 degrees above. First check your fluid level and make sure you see coolant flowing.
Old Feb 20, 2011 | 05:28 PM
05Slowline's Avatar
yeah that is way too high it's like 40 degrees at best outside right now lol, check your hoses for kinks, did you do the laminovas correctly, did you do your hose routing correctly, do you have the .040 orifice in the bleeder line, etc.
Old Feb 20, 2011 | 05:29 PM
srt-10's Avatar
130 sounds normal, what temps is your weather at?. I had the TVS with stock pulley, meth injection, CA H/E, 2 step colder plugs, injen CAI, 11.9afr and 25* timing and i was only seeing 140* after 3 pulls back to back on a 35*C day.
Old Feb 20, 2011 | 05:31 PM
its like 50 degrees out
Old Feb 20, 2011 | 05:32 PM
defo98's Avatar
He said his is at 130 cruising around. Mine stays around 70 when I cruise on a mid 40 degree day
Old Feb 20, 2011 | 05:34 PM
05Slowline's Avatar
lol 95 degrees on a stock pulley, more efficient (less heat) blower isn't really comparable to an m62 in 50 deg weather.
but like i said you can never accurately compare iat's with someone else way too many variables. 130 is too high though.
also check ic pump.
Old Feb 20, 2011 | 05:38 PM
how can i tell if the pump is dead?
Old Feb 20, 2011 | 05:41 PM
05Slowline's Avatar
eh with option b it's kinda hard, is it the og pump?
if it is and you've got 40-50k on it i'd say it's a safe bet that's what it is.
Old Feb 20, 2011 | 05:43 PM
yea its the original pump and my car has like 70k on it
05Slowline's Avatar
oh wow haha, i'd say that's the most likely cause then.
you can try tapping it with a hammer or something to see if it'll start up again, that won't work forever though haha.
Old Feb 20, 2011 | 05:50 PM
how much are they to replace?
Old Feb 20, 2011 | 06:15 PM
defo98's Avatar
Cobalt & Ion ---> ZZ Performance
Old Feb 20, 2011 | 06:16 PM
05Slowline's Avatar
Bosch Intercooler Pump - Over The Top Performance
or just search ebay for bosch intercooler pump
it's the same one used on 03/04 cobras
Old Feb 20, 2011 | 07:02 PM
srt-10's Avatar
opps, missed that, yea something is fuckie...
Old Feb 21, 2011 | 02:07 PM
how will tapping it with a hammer work? and should the car be on when i do that?
Old Feb 21, 2011 | 02:10 PM
xnigelx's Avatar
it sometimes causes it to loosen up.. its a trick for nearly any pump but as stated its a temp solution. and yes do it while its on
Old Feb 21, 2011 | 02:11 PM
defo98's Avatar
Someone correct me if i'm wrong but there are like metal brushes on the inside that after a while get stuck. Hitting it with a hammer will knock it loose and it should work but only for a little while like a week or so ive seen peoples go a month after but you should definately replace it. Hit it with the car on
Old Feb 21, 2011 | 02:12 PM
lol ill try and see if my temps go down, and look for kinks and everything. Somethings always wrong...
Old Feb 21, 2011 | 02:17 PM
hoffa's Avatar
that is too high for those mods.
if it isn't the pump, you have something plumbed incorrectly.
Old Feb 21, 2011 | 02:19 PM
Is there any real way to tell if the pump comes on?
Old Feb 21, 2011 | 02:20 PM
scotch89's Avatar
i tore into my pump and you wouldnt belive how much crap falls out. after i did that its hasnt stop working. there is a how to on doing it pretty simple. if you take the filler cap off and put something in it like a straw and see if it tries to pull it, or move from the coolant being pulled. that or pop your hood go and start your car and get out real quick and stare at the filler neck. if nothing starting going threw or bubblen its probely bad. it take about 15 sec for the pump to kick on after car has been started.
Old Feb 21, 2011 | 02:22 PM
I have opt b, should i be able to see movement in the tank?
