Ic pump wiring
Old Jun 15, 2013 | 01:18 AM
cOHbalt's Avatar
Ic pump wiring
So I was chilling with my buddy at a meet and he owns an ion. He said for the redlines a lot of their ic pump wiring was backwards leading them
To fail easily. I just replaced my ic pump and was wondering if GM might have switched the wiring on my 05 ss. I wanted
Ask before I lifted my car
Old Jun 15, 2013 | 09:16 AM
mrbelvedere's Avatar
that was not a problem n the cobalts
Old Jun 15, 2013 | 09:27 AM
cOHbalt's Avatar
So only for the redlines?
Old Jun 15, 2013 | 09:31 AM
Tjolley's Avatar
Think it was only the 04 redlines
Old Jun 15, 2013 | 09:35 AM
cOHbalt's Avatar
Okay I knew it was 04 and some 05 my car is pretty low so I wanted to make sure before I had to get under there.
Old Jun 15, 2013 | 12:32 PM
cOHbalt's Avatar
Why was this a problem with the 04-05 redlines and not the 05 cobalt ss??
Old Jun 15, 2013 | 12:34 PM
blueLNFftw's Avatar
Redlines were built first.
Old Jun 15, 2013 | 12:46 PM
ssyellow's Avatar
Yup, 2004 Redlines only. Reversed the wires.
Old Jun 15, 2013 | 01:16 PM
cOHbalt's Avatar
Thank god I wasn't goin to replace another pump because of damn GM
Old Jun 27, 2013 | 11:56 PM
cOHbalt's Avatar
Okay is the flow suppose to be left to right? I put i straw in and it pulled to the right (toward the driver side)
Old Jun 28, 2013 | 12:14 AM
06cobaltncng's Avatar
im pretty sure mine doesnt flow...
Old Jun 28, 2013 | 12:24 AM
cOHbalt's Avatar
The ic pump should give you flow? I want to know if my flow is the correct direction
Old Jun 28, 2013 | 12:30 AM
I meant I think mine doesnt work. but im sure left to right is correct
Old Jun 28, 2013 | 11:50 AM
cOHbalt's Avatar
Well that's not good. I just need to know what way it flows I believe mine might be backwards (left to right)
Old Jun 28, 2013 | 11:54 AM
it comes in the pump through the top and out the drivers side of the pump IF i recall correctly
Old Jun 28, 2013 | 12:02 PM
cOHbalt's Avatar
So I put in a screw driver and the top of it pulled towards the passenger side
Old Jun 28, 2013 | 12:26 PM
insylem's Avatar
That means I don't have to check mine either. I had heard some were backwards, but didn't know it was not the Cobalts. I had my IC pump fail a couple years ago. Replaced it with a ZZP one. Worked fine ever since.
cOHbalt's Avatar
Yeah I replaced mine as well but mine flows left to right which is wrong
Old Jun 28, 2013 | 12:27 PM
insylem's Avatar
When I take the fill cap off, and run my car. It's pretty obvious, just watching it I can see it flowing good.
Old Jun 28, 2013 | 12:28 PM
cOHbalt's Avatar
But if it flows in reverse it decreases a lot of thkngs
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
jmelton327
Sep 26, 2015 10:04 PM
