IC question?
Old Dec 9, 2011 | 06:01 PM
zerosk8ter83's Avatar
IC question?
does a IC pump suck and blow or does it just blow?( no homo)
Old Dec 9, 2011 | 06:23 PM
SlowCobaltSS's Avatar
Old Dec 9, 2011 | 06:29 PM
sternerG85SC's Avatar
does neither... its pumps
Old Dec 9, 2011 | 08:35 PM
Leafydialupking's Avatar
It creates a pressure differential which causes the fluid to flow.
Old Dec 9, 2011 | 10:29 PM
Sharkey's Avatar
see above.
now your engine on the other hand, it sucks squeezes bangs and blows.
Old Dec 10, 2011 | 12:58 PM
thanks for the feedback I was just wondering because I noticed my pump wasnt pumping alot of water back into the B tank.
Old Dec 10, 2011 | 03:55 PM
tap your IC pump slightly with a hammer, i mean very slightly lol sometimes they can get stuck, IMO if its starting to fail just buy a new one... peace at mind.
Old Dec 10, 2011 | 11:58 PM
insylem's Avatar
From what I understand Option B tank is an overflow and wont have much flow through it. Check in the stock fillerneck for water flow. I do not have Option B so I could be mistaken though.
Old Dec 12, 2011 | 04:24 PM
dmbii83's Avatar
if you reverse the polarity yes it will flow backwards its just a electric motor
Old Dec 12, 2011 | 06:03 PM
Well kind of, that pump is really only design to flow one way and wouldnt do too good of a job flowing backwards.
Old Dec 13, 2011 | 12:41 AM
I dont want it to flow backwards....I want it to flow through the system at 10psi...lol
Old Dec 13, 2011 | 01:39 AM
insylem's Avatar
The motor will operate backwards, or depending on the way its constructed (Some Motors will run the same direction reguardless of electrical current direction)
However, the style of pump (Centrifigal impeller) I seriously doubt it would flow much if any water in the oppsite direction if you ran it backwards.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
