IC System help..High IAT2s
Old Apr 16, 2012 | 01:50 PM
volsfan92's Avatar
Ok so the temp outside has been around 75ish and cruising iat2s stay around 125-140 which seems high..Ive got air out of the lines, hit pump, and everything but they are still high.. at the little cap thing there is bubbles and a noticeable difference in the cap if I unplug pump..what could be my issue?
for cooling I have zzp s3 h/e and meth but havent really been into meth due to break in lol
Old Apr 16, 2012 | 01:55 PM
yellow dragon's Avatar
I am having the same issues. I thought I had it bled good but I did it again and there was a bunch of air in it still, now it's fine.
Old Apr 16, 2012 | 02:00 PM
chood711's Avatar
Get option b.. that will help with bleeding when it will also put more coolant in the mix to help with cooling..
Old Apr 16, 2012 | 02:06 PM
volsfan92's Avatar
How do you bleed yours just let it sit and run or what??
Old Apr 16, 2012 | 02:45 PM
volsfan92's Avatar
I think it may have something to do with iat1...its 72 outside and iat1 are 105 and iat2 are 140ish..I have kn Cai
Old Apr 16, 2012 | 02:51 PM
K-Train04RL's Avatar
1 and 2 should be like 30-40 degrees apart on cruising. Any higher and u have an issue
Old Apr 16, 2012 | 02:57 PM
volsfan92's Avatar
Well that's what they are but iat1 shouldn't b that high
Old Apr 16, 2012 | 03:03 PM
nizzle's Avatar
are you sure your pump is working? If so, make sure you got flow. One time I put brand new pump in due to high iat's, and still had high iat's and no flow. I took one of the lines off and blew thru it (primed it) and BAM! Problem solved. Oh yea, the pump it originally took out to replace with a new one....... worked just fine. The IC system just had to be primed in my case.
Old Apr 16, 2012 | 03:09 PM
zrated89's Avatar
alot of times even with opt B to prime it remove the line to goes to the pump from your T, fill with coolant and that will prime her
Old Apr 16, 2012 | 03:14 PM
Orange07ss's Avatar
Since your iat1 is so high compared to the ambient temp, I would check and clean the maf.
Old Apr 16, 2012 | 03:28 PM
volsfan92's Avatar
I'm getting flow from pump I just replaced not too long ago and I also cleaned my maf 2 weeks ago.. the only thing I didn't do was use the kn recharge kit on my filter if that matters..
Old Apr 16, 2012 | 04:20 PM
volsfan92's Avatar
Well on my 15 min drive home..my iat1 went down to around 85 but iat2s were still 125-140..no pulls were made just crusing and some stop and go
Old Apr 16, 2012 | 05:53 PM
microgab's Avatar
I have the same issue at the moment...it was a warm day, 77 outside and my temps were 140 crusing and 180 WOT (at least I didn't lose to a 1.8T Jetta LOL). I won't go WOT until I fix it...what is the best way to make sure there is no air left? I have a day off thurday...
Old Apr 16, 2012 | 06:10 PM
volsfan92's Avatar
Idk man I'm trying to figure it out
Old Apr 16, 2012 | 06:18 PM
Orange07ss's Avatar
Well if you're seeing bubbles then you definitely have air still in the system. What I did was loosen the fill cap and drive it around for a few minutes and then add/check level. It took me several days of driving to work as well to get the air out. (40 miles one way)
Old Apr 16, 2012 | 08:04 PM
mrbelvedere's Avatar
its still got air in it
Old Apr 16, 2012 | 11:15 PM
volsfan92's Avatar
Alright I guess Ill try that
Old Apr 17, 2012 | 05:21 PM
microgab's Avatar
isn't there a how to for this?
Old Apr 17, 2012 | 05:31 PM
zerosk8ter83's Avatar
check your lines,make sure theres no kinks
Old Apr 17, 2012 | 09:10 PM
volsfan92's Avatar
They are starting to get better now
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
