I will see if I can get some pictures. It really is easy, the hardest part is disconnecting the electrical connector from the TB.
I'm not sure on a 2.0 engine but here's the steps for a 2.2 or 2.4.
disconnect negative battery terminal using deep socket or something Remove part of intake closest to engine. There is screw under the giant black baffle that loosens a clamp. Remove the electrical clip on the TB. This is done by moving the grey or white C-clip to the side then sliding a small flat screw driver between the clip and the holder on the TB. That's a bad explanation without pics. There are 4 10mm (i think) bolts that hold the TB to the intake manifold. Remove them Once free clean and reverse steps |
well guys indeed it did work idle is much better now with and without a/c, i don't know if its abnormal but its idling around 1500rpm and it stays their and when the a/c is on drop almost to 1000rpm but other than that pretty good. I didn't disconnect the negative battery terminal and i don't know if thats really necessary or not ? but so far so good.
Same here, I did it and my car idled 100% better!:D
PS. I just cleaned it with some methanol. Didn't see any need to need in buying the cleaner. |
Originally Posted by msatchmo
(Post 2479610)
For those of us who are afraid to tear our new cars apart, could anyone be so kind to post some pics of what i'm looking for?
the yellow arrows show where the bolts to take off the tb are (there are 4) the white arrow shows on which side most of the crud will be (at leat it was on mine) there will be a black cable attached to where the red arrow is pointing, its just cliped on used screwdriveer to unclip. the "crud" looks something like the stuff thats in the SC in the pict (the black stuff)
Originally Posted by rnjmur
(Post 2479821)
HOW COME THIS HASNT BEEN STICKIED YET!!:cssNET: |
man, you must be color blind :lol:
Subscribed. Mine is misfiring at idle & threw the P0300 code recently. Think this will help or is that a whole different problem? I'm taking it into the dealership thursday & I might try this if it's still misfiring afterwards.
subscribed
Originally Posted by 06 pursuit gt
(Post 2480606)
http://i178.photobucket.com/albums/w...dyedited-1.jpg
the yellow arrows show where the bolts to take off the tb are (there are 4) the white arrow shows on which side most of the crud will be (at leat it was on mine) there will be a black cable attached to where the red arrow is pointing, its just cliped on used screwdriveer to unclip. the "crud" looks something like the stuff thats in the SC in the pict (the black stuff) i didnt disconnect the connector from the throttle body because it was too diffucult so i just cleaned it in the engine bay HOW COME THIS HASNT BEEN STICKIED YET!!:cssNET: |
i have a minor occurance of this but also my cruise control doesnt work wtf i think it needs to be flashed but still i mean come on.
Originally Posted by bgbearcatfan
(Post 2480626)
it's alright, good instructions non the less haha
just did this, smoothed out my idle a lot, and no more missfires! Thanks!
as long as you're careful, you don't need to disconnect your wiring.....just put a rag under the TB while you're spraying to protect everything around it. I couldn't disconnect mine and this is how I dealt with the problem.
for those of you having hard times disconnecting the wire, keep in mind there is a little clamp that pops off first. I believe it is blue colored and in the shape of a U
How do I get this post STICKIED??? I feel so good that I was able to help out many of you other balt owners out there. Gives me a great sense of satisfaction especially since the fix isnt hard at all. I am newer to this site and I will post pics of my car soon on here after my oil catch tank is installed.
i vote for sticky, this is one of the best threads in a while.
what did u use to clean the TB?
and i threw a p0300 code the other day which is a cylinder misfire and all my plugs are fine. i am getting different ones however, but could the debris i found in the TB possibley be the reason i threw that code? |
Originally Posted by Altiery54
(Post 2482524)
and i threw a p0300 code the other day which is a cylinder misfire and all my plugs are fine. i am getting different ones however, but could the debris i found in the TB possibley be the reason i threw that code? got it to look brand new... cant begin to tell u what a difference it made. |
Originally Posted by originaladrian
(Post 2482538)
i just used water, a damp towel and elbow grease. mine was REALLY guncky.
got it to look brand new... cant begin to tell u what a difference it made. and any advice on how to get the little electrical plug off cause its a pain in the ass |
(Post 2482540)
u think it could be why i have misfires at idle? and why i threw that code>?
and any advice on how to get the little electrical plug off cause its a pain in the ass to take the electrical plug off you need to take the little plastic clip on the plug off first.. or pull it out, i forgot... this should be move to general cobalt and stickyed for sure... |
(Post 2482547)
not sure abt the misfire. doubt it... but couldnt hurt to try.... clean ur TB and reset ur codes by disconnecting ur battery for 15 min.
I am going to have to check mine out! Thanks for the post Angel!!
the main thing i noticed after i did this is that my RPMS dont drop super low and then jump up agian after i rev my car. now its just smooootthhhh.... thanks angel!
WoooHooo sticky! I am def going to try this when I get off work!
