idler pulley question
Old Feb 28, 2006 | 10:48 PM
NJCOBALTSS's Avatar
which vendor sells the bigger idler pulley, i purchased the sfphq 2.8 and a 3.0 and il need the idler pulley for the 2.8, i did a search but didnt come up with a certain vendor
thanks
Old Feb 28, 2006 | 11:38 PM
BilletFlow's Avatar
Non Authorized / Non-Supporting
I have them
Old Mar 1, 2006 | 12:03 AM
BlAckOnBLaCK's Avatar
what size is your idler pulley? I heard that if you put on a 3 inch one you have to grind down the stock tensioner and spray paint it.
Old Mar 1, 2006 | 06:38 PM
ninja44's Avatar
Nah Billetflow machines the idler pulley and no grinding necessary and they are 3". Billetflow is the shizznit and the pullies are pure quality. Waiting on my order to get to Wisconsin Doug
Old Mar 1, 2006 | 09:30 PM
03gobluecobra's Avatar
another vote for billetflow.
Old Mar 1, 2006 | 09:56 PM
cmkinzer's Avatar
Can you tell me what the link is for the idler pulley?
Old Mar 1, 2006 | 10:20 PM
05_Blue_B10WN_SS's Avatar
Same. With a 2.8" pulley i will need the 3.0" idler pulley correct? Link Please.
Old Mar 1, 2006 | 10:23 PM
FAST06SS's Avatar
Can we see pics? I have physically done my own and i can tell you with GOD as my witness, there is NO WAY you can fit a 3" pulley w/o modifying the braket or w/o having belt alignment issues.
Old Mar 1, 2006 | 10:25 PM
ninja44's Avatar
Maybe Doug from Billetflow can address this?
Old Mar 1, 2006 | 10:30 PM
FAST06SS's Avatar
That would be cool! Maybe i need glasses in my old age Or micrometer is out of adjustment???
Old Mar 1, 2006 | 10:35 PM
ninja44's Avatar
What size is the intense idler pulley?
Old Mar 1, 2006 | 10:42 PM
FAST06SS's Avatar
3" standard ansi groove pulley
Old Mar 1, 2006 | 10:48 PM
ninja44's Avatar
Just checked and got some info, the Billetflow idler is 76mm (3.04") and apparently a bunch of Redline guys are using it with no grinding and no issues. I am actually using the idler as a temp solution and waiting for an adjustable tensioner bracket.
Old Mar 1, 2006 | 11:04 PM
FAST06SS's Avatar
Pics of it sitting on an unmodofied bracket and how much?
Old Mar 1, 2006 | 11:08 PM
ninja44's Avatar
Guys are actually running it in their cars. Price retail I believe is about$25.
Old Mar 1, 2006 | 11:17 PM
FAST06SS's Avatar
I understand that, i just would like to see how it is done since there is no info on the website.
Old Mar 1, 2006 | 11:28 PM
djt81185's Avatar
its a big secret. Mine should be here tomorrow. i'll steal the ex gf's camera and try to get some pics.
Dan
Old Mar 2, 2006 | 02:39 AM
I spoke with doug and he said that it is 70mm.
Old Mar 2, 2006 | 02:40 AM
Dan
Let me know if you can install that puppy and not have to grind anything.
Old Mar 2, 2006 | 08:31 AM
FAST06SS's Avatar
Finally, the truth! Thank you !!!!!! I knew it couldn't have been a 3" pulley
70mm = 2.76"
Stock = 2.5"
Old Mar 2, 2006 | 08:45 AM
eastcoastz's Avatar
Anyone have pics of where you have to grind on the idler?
Old Mar 2, 2006 | 09:20 AM
memphisr24's Avatar
Does the "2.76" inch idler pulley from billetflow make the belt slip with a 2.8 inch pulley? Or is it enough to stop the slip?
Old Mar 2, 2006 | 09:54 AM
FAST06SS's Avatar
3.31"- 2.80" = .510"
The pulley is .250" bigger so i would say ?????
Old Mar 2, 2006 | 10:29 AM
djt81185's Avatar
iirc you can drop to a 3" without slip. That is .31" drop. As long as 3.31-(your pulley size)-(the size in inches your idler is bigger....250" in this case)= less than .310 you should be fine.
So you should be able to go to a 2.7 with probably no slip a 2.7 yields .36. The BF pulleys are sandblasted and have proper v groove geometry so you shouldnt have any slip problems at 2.7...also any smaller and you need to machine the blower snout.
Old Mar 2, 2006 | 10:43 AM
memphisr24's Avatar
Could you use the idler pulley with the tensioner at the same time? (stupid question, my brain seems to think you can though, I mean why not?) Because I would like to do the cheap idler pulley for like 30 bucks but if the belt starts slipping, I would use the tensioner in conjunction with the idler pulley.
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
