Originally Posted by Omega_5
(Post 2331939)
*sigh*
Yes... using 110 they are the right ones... The ones posted before were also the right ones... but not for our engines. Instead of looking up the EVO numbers, I just looked at the DSM spec sheet sitting on my hard drive.... much simpler and quicker in order to get the point across, considering I have stuff to do at work. They still were not correct even using DSM lobe seperation angle. You did the math on the opening and closing points @ 1mm and not advertised like I originally stated. The spec card you quoted is correct but your math on overlap and LSA is not...you posted lobe seperation angles in excess of 130 degrees and overlap in the single digits. :eek: Overlap using your centerlines and info on DSM cams: 264/264 -> {[(264+264)/4]-110}*2 = 44 degrees overlap 272/272 -> {[(272+272)/4]-105}*2 = 62 degrees overlap 264/272 -> {[(264+272)/4]-106}*2 = 56 degrees overalp 272/264 -> {[(272+264)/4]-110}*2 = 48 degrees overlap
(Post 2331701)
Yes... my differential EXPLODED... so I need to get my original trans (synchro problem) fixed. BUT, if I can't find someone that is willing to work on an F35 MU3 Trans... then I think I am going to be stuck buying a new/used trans. :(
Either way... cams gotta go. |
back story.
the 264 intake and 272 exhaust dsm set up was to help the smaller turbo guys get more top end pull. also they wouldn't have to dick with the idle to prevent the idle surge issue and other things here and there. not as much power as a straight 272. a smidge more than a straight 264. i hate math. cereal. |
Originally Posted by Area47
(Post 2332190)
back story.
the 264 intake and 272 exhaust dsm set up was to help the smaller turbo guys get more top end pull. also they wouldn't have to dick with the idle to prevent the idle surge issue and other things here and there. not as much power as a straight 272. a smidge more than a straight 264. i hate math. cereal. This is why I said to reduce the intake cam as reducing the exhaust cam duration limits top end airflow while still giving poor low end with the larger intake cam. With the exhaust side longer than the intake, you help uncompressed exhaust scavenge but still exhibit good low end torque since the higher duration intake cam that allows compressed air to ingest is not needed. With the HKS Evo grind the overlap would be the same on both cam setups no matter the combination. |
Originally Posted by Witt
(Post 2332221)
srsly
This is why I said to reduce the intake cam as reducing the exhaust cam duration limits top end airflow while still giving poor low end with the larger intake cam. With the exhaust side longer than the intake, you help uncompressed exhaust scavenge but still exhibit good low end torque since the higher duration intake cam that allows compressed air to ingest is not needed. With the HKS Evo grind the overlap would be the same on both cam setups no matter the combination. i enjoy the fact when something gets technical on here. only about 5 people actually post about it. there is a downfall to the evo grinds in our engine. i have found it. others have as well. the numbers don't show it. however comming up with 130 degree's is way out there |
(Post 2332271)
(Post 2332271)
yepo, in a nut shell.
Originally Posted by Raven SS
(Post 2332307)
not everyone enjoys hearing from everyone else how wrong theyare whenthey know they arent when they post technically shit like in the intake manifold thread..its very hard posting information that helps with these cars when people that dont even plan on do said mod argue that fact that u dont NEED it...
(Post 2332317)
Eh, its good hearing those opinions though imo. What isn't needed is the insults when someone only "thinks" they are right or even if they are correct. I'll take a good discussion any day but when insults are relied upon to try to support an opinion I can't help but laugh.
(Post 2332307)
not everyone enjoys hearing from everyone else how wrong theyare whenthey know they arent when they post technically shit like in the intake manifold thread..its very hard posting information that helps with these cars when people that dont even plan on do said mod argue the fact that u dont NEED it...
witt. the cams of win :) |
witt you wouldn't happen to have a pic of the shims that were sent with your cams? I'd like to see it
Originally Posted by fast98
(Post 2332340)
Area47 tried having a set machined with a flange so they wouldn't slip but lifter-bore clearance inhibited their use. |
(Post 2332351)
They are simply machine washers. Bates uses a similar technique.
Area47 tried having a set machined with a flange so they wouldn't slip but lifter-bore clearance inhibited their use. :) m10 is the shim size. this varies greatly in size. roughly 2.0mm is the thickness |
(Post 2332124)
Ouch, happen on the track or on the street if you don't mind me asking?
Later on, I had a friend tell me that the official stopped me about 2 ft before the burnout box. So I'm thinking that either a roll pin just decided to fall out... or that I got WAY too much traction, which is what I think happened, considering how much VHT was on the ground from the Slick cars running for the previous 3 hours. https://www.cobaltss.net/forums/problems-service-maintenance-69/usmcfieldmp-vs-f35-tranny-107667/ Pics are in post...32 or something |
Looks familiar.
should!
well, not exactly. a few things in the pic are different. i was staring at the pic and trying to figure out where the 130 degree's came from ::shrugs:: |
(Post 2332307)
For example, one person talks about valve overlap, the next person assumesyou mean lobe overlap, and gets all sandy vagina on you about it. :lol: It's shit like that, why I've deleted most of the technical stuff I've ever put on this forum. If people want to start making assumptions on my behalf, I'll stop posting stuff. The other thing, is when people get all hard headed about stuff, and when there's an alternative they, again, get all sandy vagina instead of asking people to explain.... then again, i can't really blame them... how many people will actually take the time out of their busy day to reply to a PM? So, fuck it... I'm down shifting into An0 mode, and gonna lurk and laugh for a bit.... answer a few PM's and stuff.... maybe while I'm lurking someone can post a how to for "keeping your cooter clean". :lol: |
(Post 2334714)
What actually pisses me off is when people flame you with out looking at what your actually talking about.
(Post 2334375)
should!
well, not exactly. a few things in the pic are different. i was staring at the pic and trying to figure out where the 130 degree's came from ::shrugs:: Edit: other than the exhaust and injectors. |
(Post 2331701)
Originally Posted by wisemanonice
(Post 2336707)
the ss/sc has a f35 trans right? then whats a f35 mu3?
(Post 2336722)
F35 is actually a model number based off torque rating (350 newton*meters). The MU3 is an RPO code. Multiple transaxles can have the same model number but can also have different final drives, revisions, etc. The MU3 is an identifier on that specific type of transaxle and usually any further revisions or changes will be designated with a new RPO though this isn't always the case.
:rolleyes:
Again with the not reading... And again this the sand... https://upload.wikimedia.org/wikiped...beach_sand.jpg OK... bye bye now... :bye: |
(Post 2336637)
What exactly is different? Didn't you use 78lb Supertech valve springs as well? Edit: other than the exhaust and injectors. winna! dunno. i got nothin here is your chance to explain your reasoning behind it all. i wasn't "bashing" i however was looking at the numbers funky |
(Post 2336743)
Oh, so his trans has been modified from what the stock trans was is some way?
And again this the sand... [ ] dum [ ] jay [ ] shtewpit check all that apply
(Post 2336743)
