Informational: How not to make a timing table
Old Oct 26, 2012 | 03:17 PM
Dart_SI's Avatar
Originally Posted by 100% METH
let's leave this in the TVS thread please
this thread is black and white information only
This. THIS! stay in topic!
Old Oct 26, 2012 | 03:18 PM
Pleass's Avatar
Originally Posted by BPacak
what about boostedpattywagon?
noiceee
Old Oct 26, 2012 | 03:19 PM
Gelladuga69's Avatar
Sub'd. Would like to learn more about this.
Old Oct 26, 2012 | 03:20 PM
Vander Nars's Avatar
I didn't make it
If you have the power to do so, please delete Steven Flit from the forum. Or at least point me in the right direction to do so myself. It's been inactive for 2 years
so u made another account to flame someone wow.
Old Oct 26, 2012 | 03:21 PM
Team SS's Avatar
TTR Powered
In before the
Old Oct 26, 2012 | 03:22 PM
100% METH's Avatar
pattywagon isn't my sn
Steven Flit & 100% METH are
S flit is a account I made when I first joined the forum in 07, been inactive for some time. All my dyno testing, mp90, lysholm has been posted under 100% meth for 2 years now.
Old Oct 26, 2012 | 03:23 PM
Pleass's Avatar
so bpack is making this up? doubt that
Old Oct 26, 2012 | 03:24 PM
100% METH's Avatar
Dunno what he's thinking... my photobucket are being shared though
Old Oct 26, 2012 | 03:25 PM
the one thing I can say about bpacak is iv never seen him lie about someone being who he says they are so unless im miss understood what he said that seems to be the case
carstedt's Avatar
a friend prolly used his wifi or sumtin to make another acct if its showing up as the IP...could be wrong but back on topic! trying to learn a little from this
Old Oct 26, 2012 | 03:26 PM
  #36
Chevycobaltss3's Avatar
here is a email i had due to the maf calibration being skewed: Ok, i need you to do me a favor. Check your methanol check valve because trims in cruise and idle fluctuate a whole lot as if the meth is getting sucked in.
Meth was puddling up in the mani.
  #37
100% METH's Avatar
yeah man
you know I've been on this sn... I have no reason to make another name
  #38
BPacak's Avatar
Vtec Rep
lets see, both have the same current ip address, which of course comes up as LA not ky which is where boostedpattywagon is located.
Old Oct 26, 2012 | 03:27 PM
  #39
now i cant wait to see him explain this, I cant believe he was too scared to call james out on his account he made a new one to flame him.
Old Oct 26, 2012 | 03:28 PM
  #40
zrated89's Avatar
The fact is that isn't close to being a tune. As I've said time and time over. James please continue to blow people's cars up and claim is mechanical issues on a bone stock motor. You are no tuner at all.
Old Oct 26, 2012 | 03:30 PM
  #41
zrated89's Avatar
Who the hell cares if he made it or not. Personally ill call it how I see it always have. Some people don't like drama I could care less if someone's feelings are hurt If they are wrong they're wrong period
Old Oct 26, 2012 | 03:31 PM
  #42
carstedt's Avatar
can we get back on topic and get sum good info from this for people like me who would like to learn more about this
  #43
100% METH's Avatar
Rather than take this the wrong way James, why don't you just learn from your mistakes
Just because you've been tuning as long as you have... doesn't mean you fully understand how to tune a LSJ. This is proof that you don't fully understand
Old Oct 26, 2012 | 03:34 PM
  #44
seems like you dont understand the rules about not having multi accounts.
Old Oct 26, 2012 | 03:35 PM
  #45
zrated89's Avatar
Can't talk his way out of this. Joe and I have several tunes like this from him. But I weren't going to waste my time posting them.
  #46
Area47's Avatar
Rent me! per hour
lesson time kids
deviating from the stock timing curve will yield less over all horsepower and torque. peak torque happens at peak cylinder pressure. which is why you see less commanded timing in these load cells. as rpm increases, cylinder pressure drops. this is why you see an increase of timing after peak torque to make up for the loss of cylinder pressure.
going 10 degree's above MBT will just result in unneeded wear on the rod bearings as they that a lot of the force exerted when combustion hits. {see blown up lnf pics for reference}
running 11-13 degree's of ignition timing in the part throttle cells can result in high egt's which can translate into higher than desired egt's in higher load cells.
  #47
zrated89's Avatar
If I were you I'd be a little less worried about him and more worried about getting a real tune on your car.
Old Oct 26, 2012 | 03:36 PM
  #48
Area47's Avatar
Rent me! per hour
if that is the only leg you have to stand on, you better sit this one out.
Old Oct 26, 2012 | 03:37 PM
  #49
Sox-Fan's Avatar
Got Brakes?
Guys, rather than make a big deal about screen names let's actually add some information to the topic that is, after all labeled as information.
The pics don't do **** all for me. I have no idea what I'm seeing there.
So, someone spell it out please: this is what he's doing wrong, this is why it's wrong, this is what he should be doing.
  #50
zrated89's Avatar
Originally Posted by Area47
lesson time kids
Exactly. And you could see the results from run away kr on blues sleeves but that's right is was simply mechanical lmao
