Ingalls Torqyue Damper
STILL GETTING SOME WHEEL HOP IN FIRST GEAR RIPS!
I SET IT TO 13MM, I NOTICED EVERY1 HAS SET IT TO 12MM BUT SHOULDNT IT HOP LESS EVEN IN 13MM? OR MAYBE ANOTHER POSSIBLE REASON?
NEED SOME FEEDBACK THANKS
Also, no, it should be be installed on an angle. There are adjustments on the torque damper to make sure the holes line up paralell and that the torque damper is straight....
Didn't you guys read the instructions and warranty provided? If it breaks under improper adjustment, your warranty for the damper is voided.
DANRICKARD
Oct 1, 2015 12:08 AM
2.0 LSJ Engine: How to install the "INGALLS Engine Damper" for your Cobalt SS/SC
denny
How to Guide
206
Mar 22, 2014 06:43 PM
