injectors-stock
injectors-stock
how much power do the stock 32lb injectors handle? my 2.2 may be going static once i do some retuning. i know the math and all that, plus that we have a higher than the tested pressure to rate injectors at (unless GM claims 32@56psi @ fuel rail).
basically i think that 32lb injectors should be more like 40 with how the math all works out and i just wanna know how much someone has pushed to the wheels off stock injectors cuz i will have over 200whp
i got a 2.2l. what would i have to do for injector harness? is there a thred on here for that? (sorry too lazy to look at the moment)
I believe Hunterkiller showed how to adapt the 2.0 injectors to a 2.2 harness in his supercharge how-to.
Here it is:
https://www.cobaltss.net/forums/how-guide-43/hunters-how-install-m62-2-2l-cobalt-127891/
Here it is:
nice. im trying to get in the LOW 14s maybe 13s w/o spray before i go with the hahn stage 5 turbo kit for the lsj's then im going for 400+whp but thats still only in my mind if i wanna do or not lol. i think you will hit 14s with the cams. that 2.4 manifold you sold me woulda helped lol its like cams (lose bottom, gain top)
so is that saying that the stock ss/sc injector harness is what i need? and does the stock ss/sc injector harness work for 42.5lbers?
