injectors-stock
Old Oct 28, 2008 | 08:38 PM
o3nisoaso3's Avatar
injectors-stock
how much power do the stock 32lb injectors handle? my 2.2 may be going static once i do some retuning. i know the math and all that, plus that we have a higher than the tested pressure to rate injectors at (unless GM claims 32@56psi @ fuel rail).
basically i think that 32lb injectors should be more like 40 with how the math all works out and i just wanna know how much someone has pushed to the wheels off stock injectors cuz i will have over 200whp
Old Oct 28, 2008 | 08:42 PM
Sw4y1313's Avatar
I think you will be ok, may be pushing the IDC's a bit over 80% though.
Old Oct 28, 2008 | 08:44 PM
EXsoccer1921's Avatar
you'll have breathing room. but just get 42# and then tune once you get them
Old Oct 28, 2008 | 08:49 PM
o3nisoaso3's Avatar
yea i figured id be up past that but i was hoping not too far. i didnt wanna push past 80% tho so thats why i asked bout ss/sc injectors
i got a 2.2l. what would i have to do for injector harness? is there a thred on here for that? (sorry too lazy to look at the moment)
Old Oct 28, 2008 | 09:10 PM
XM15's Avatar
I believe Hunterkiller showed how to adapt the 2.0 injectors to a 2.2 harness in his supercharge how-to.
Here it is:
https://www.cobaltss.net/forums/how-guide-43/hunters-how-install-m62-2-2l-cobalt-127891/
Old Oct 28, 2008 | 09:14 PM
o3nisoaso3's Avatar
thanks joel
hows the winter build coming? (cams)
Old Oct 28, 2008 | 09:16 PM
XM15's Avatar
In the works.
I also picked up an M62 from a friend in town who went turbo, but that will be a little further down the road.
I want to see how close to the 14's I can get n/a.
Old Oct 28, 2008 | 09:26 PM
o3nisoaso3's Avatar
nice. im trying to get in the LOW 14s maybe 13s w/o spray before i go with the hahn stage 5 turbo kit for the lsj's then im going for 400+whp but thats still only in my mind if i wanna do or not lol. i think you will hit 14s with the cams. that 2.4 manifold you sold me woulda helped lol its like cams (lose bottom, gain top)
so is that saying that the stock ss/sc injector harness is what i need? and does the stock ss/sc injector harness work for 42.5lbers?
Old Oct 28, 2008 | 09:50 PM
Sizzle06's Avatar
Do you have injectors?If not i have a set i'm selling.let me know.
Old Oct 28, 2008 | 10:10 PM
o3nisoaso3's Avatar
yes actually. i have had a set for 3 years. turbo build back in mid 05 n then sold everything cuz it was a bitch but i never got to installing them
