Installed zzp stage 2, few concerns
Old Jul 27, 2010 | 02:11 AM
Dash71121's Avatar
i installed the pulley (2.7) injectors (60lbs) spark plugs and put in their stage 3 heat exchanger today.
i drove it around a bit and have no cel's. i was under the impression that i would get a check engine light for the crank case relearn.
my other concern is once in a while at idle the rpms will fluctuate.
i bought the kit used (the injectors, pulley and ecu)
i am loving the power though lol
Old Jul 27, 2010 | 02:13 AM
05Slowline's Avatar
check engine light should be the crank relearn.
fluctuating idle, that comes with a canned tune, where is beaverton? you want the best and smoothest tune you'll want a custom tune.
Old Jul 27, 2010 | 06:01 AM
Erick161's Avatar
Def go get a crankcase relearn...
Apparently the shitty idle is "normal", even though i think thats bullshit. It shouldnt be "normal"
Old Jul 27, 2010 | 07:13 AM
SunburstSS's Avatar
I got away without doing a crank case relearn when swapped my ecu's like 3 weeks ago...or might be just waiting to come out haha...
Old Jul 27, 2010 | 08:20 AM
05Slowline's Avatar
try making a canned tune that works 100% in any condition in any place in the world and come back and say that .
he didn't say it's constant it's just a hiccup in the tables that don't work for him all the time...............
Old Jul 27, 2010 | 08:26 AM
Supercharged Guy's Avatar
Get a custom tune from any of the TT's on here really, thats probably your best bet
Old Jul 27, 2010 | 11:35 AM
Dash71121's Avatar
sorry guys i messed up on my post.. i dont have any cel's, so does that mean i dont have to do the crank case relearn?
im in beaverton, or
i'll be getting a custom tune when i can afford it, thanks for the input
Old Jul 27, 2010 | 12:19 PM
05Slowline's Avatar
is it the ecu that came in your car stock?
we know you're in beaverton, where is beaverton.
Old Jul 27, 2010 | 01:54 PM
sput's Avatar
You have to do a case relearn when you swap ECU's. Without it, your timing will be off.
Old Jul 27, 2010 | 03:26 PM
Dash71121's Avatar
beaverton, or = Oregon lol
no it is not the stock ecu, it is a zzp tuned one that came off the car that had the pulley and injectors
so even if there is no cel i should still get the crank case relearn done?
Old Jul 27, 2010 | 04:31 PM
SilverSSyes's Avatar
crank case relearn? I installed the zzp kit 4 months ago and never did this. No problems whatsoever. The timing will be off? who told you that?
Old Jul 27, 2010 | 04:36 PM
Stone629's Avatar
You should be fine. The idle thing seems to be something these cars do, not sure why. Mine started doing it also, as soon as I got my 2.7, 60s, and tune done. Who knows what the hell causes it.
I tried the throttle body cleaning as well, no luck.
Old Jul 28, 2010 | 12:51 AM
Erick161's Avatar
If you send in your PCM, no problem. You use a PCM not from you car, enter crankcase relearn
Old Jul 28, 2010 | 09:05 AM
05Slowline's Avatar
If you get a jumpy idle off 60's and an hpt tune you need to tell your tuner to try better.
ineedacobaltss
Nov 7, 2015 02:25 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
