Installing Dual pass and cobra H/E
Old Oct 26, 2007 | 12:07 AM
Coblt ss super's Avatar
wats the fastest and easiest way to do this? i wanna do mine, but seem i never have time, all i got is mondays after school, and maybe sunday after work, i get outta work at 6 on sunday and outta school at 4 on mondays think i can pull it off in those 2 days?
Old Oct 26, 2007 | 12:40 AM
LopsidedJester's Avatar
2 days is plenty of time, toughest part is getting at those bolts that are under the manifold, it took me about 2 hours to figure it out and wrench them out a quarter turn at a time.
Old Oct 26, 2007 | 12:44 AM
ItalianJoe1's Avatar
For a first-timer, don't worry about the Cobra, just do the dual-pass first. Figure on 3-4 hours total to swap it out if you haven't done it before. Its not hard, it just takes time. Pull the I/C pump bracket off when you go to do the bottom bolts, it makes it pretty easy that way.
Old Oct 26, 2007 | 12:46 AM
ok this is my biggest fear leaking lines, has anyone had any trouble with any lines leaking after they installed it?
Old Oct 26, 2007 | 12:50 AM
Nah, nothing should leak, just use good hoses and clamps and make sure everything is on correctly, it should seal. The only connections you are adding are the T hose by the endplate and the two connections on the H/E, so its not much to leak anyway. The manifold seals are all o-ringed, so they seal really well with minimal torque.
Old Oct 26, 2007 | 01:39 PM
ok i think imma install just the dual pass for now and then the cobra h/e another day since the h/e is alot easier
Old Oct 27, 2007 | 10:10 AM
how are you mounting your cobra h/e? are you using the bwoody mounting system? im thinking about going with that mounting setup but havnt heard of anyone using it
Old Oct 27, 2007 | 11:23 AM
Bwoody brackets suck for the Ion, I haven't used them on a cobalt yet. I would say just make them yourself, go get some flat metal from Home Depot or something and bend it into shape, you don't need much. There are how-to's on here that will show you what is needed.
Old Oct 28, 2007 | 01:34 AM
nah man custom brackets FTW, but imma make Z shape brackets and use 3-4 plastic zip ties, to hold it onto the brackets like blown-4-banger did and then run the lines, imma install the dual pass first one of these days and then the cobra h/e
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
