installing exhaust question
Old Feb 19, 2007 | 03:52 PM
mikess06's Avatar
hey i was wondering when installing a cat back exhaust where do you cut and then how do u get the new exhaust to hook up to the cut pipe??
Old Feb 19, 2007 | 03:54 PM
wdsoccer's Avatar
cut it right before the rear axel and unbolt it from the downpipe and resonater. it should all bolt right up then.
the new exhaust doesnt go to the cut pipe. it bolts on with the downpipe
OniMirage's Avatar
quoted for truth
Old Feb 19, 2007 | 03:55 PM
Scythe_Snake's Avatar
You have to cut something to put in a cat back for the balt? It isn't a bolt on?
Old Feb 19, 2007 | 03:56 PM
D4u2s0t's Avatar
you have to cut to get it off... every aftermarket exhaust i've seen so far comes in multiple pieces so you don't have to cut them
Old Feb 19, 2007 | 06:57 PM
stotte20's Avatar
yea you will cut to get it off but the new one will be able to bolt back up on with out major modifcation
Old Feb 19, 2007 | 07:04 PM
martinsmu's Avatar
^^^ what they all said. My suggestion, is unbolt it all, and see where you are restricted to take it off, and cut it there. But its before the axel. The new catback are all bolt ons. So the old cut catback wont affect at all your new install.
Old Feb 19, 2007 | 07:07 PM
Oh okay. That seems hard. What do you cut it with, because I want to do my header, downpipe, cat-back and intake at least. I have to cut it right before the rear axle?
Old Feb 19, 2007 | 07:12 PM
martinsmu's Avatar
saw's all is what I used. I think thats how you write it, those electric hand held machines with the metal blade at the end
Old Feb 19, 2007 | 07:14 PM
D4u2s0t's Avatar
yea, right by the axle... it's an easy install... when you try to take it off, you'll see where it needs to be cut... when you try to ge tit off, you'll see where it won't fit over the axle
Old Feb 19, 2007 | 07:15 PM
Okay. Thanks again! I'm going to get some pics and look, I'm more of a visual person. I can remember all that though. Thanks!
What tools would be needed?
Old Feb 19, 2007 | 07:20 PM
D4u2s0t's Avatar
just a socket set, or wrench, and something to cut the exhaust with... it's just really basic hand tools... except that one cut, it's literally unscrew bolts, take parts off, put new parts, screw on bolts... piece of cake... some of the bolts may be hard to get off, if they're a little rusty or old... some wd-40 is your best friend, and some muscles too
it will make things MUCH easier if you have ramps or jack stands... i don't, so i used my fathers... lift up the rear, you can get the exhaust, downpipe, and header with the rear lifted...
Old Feb 19, 2007 | 07:24 PM
Hmm, okay then. I THINK i can do that, lol. So I could do this with hacksaw right? lol
And if I wanted to do the whole header, dp, and cat-back at the same time, should I simply unbolt the headers and cut the cat-back, then replace the whole thing?
Old Feb 19, 2007 | 07:27 PM
martinsmu's Avatar
If you want to do the whole thing, unbolt everything, then cut the catback. A hack saw will work. And I would suggest go from header back when installing your new parts.
Old Feb 19, 2007 | 08:34 PM
D4u2s0t's Avatar
yes, you can use a hacksaw, not a problem at all...
when taking your stock parts off, start with the exhaust and work your way back, exhaust, downpipe, then header... like martinsmu said abou the install, start header first...
Old Feb 19, 2007 | 09:14 PM
OniMirage's Avatar
i used a grinder took forever cus of clearance but had I planned it out better it woulda taken like an hour at most total prep unprep
Old Feb 20, 2007 | 07:43 PM
Man I LOVE this community. All you have to do is ask. Thanks guys, you all were helpful. I'm feeling confident that I could do this mod now!
Old Feb 20, 2007 | 07:50 PM
OniMirage's Avatar
err uhh ... next time SEARCH ... lol jk
Old Feb 20, 2007 | 07:53 PM
I should have!!!
I should have, I honestly should have, lol.
I sort of thread jacked. i have a bad habit of that!!
Old Feb 20, 2007 | 08:02 PM
XM15's Avatar
Here's the How-to Scythe Snake!
https://www.cobaltss.net/forums/how-guide-43/how-install-cat-back-exhaust-lots-off-pics-43239/
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
Sep 27, 2015 08:53 PM
