intake install
Old Jun 5, 2007 | 08:49 PM
silverbulletss's Avatar
intake install
i've got ordered a k&n cai and looking forward to putting that on. the question is how tricky is putting on the new kit? i've heard mixed opinions. I know it depends on skill or what not but just kinda wondering. let me know what ya'll think
Old Jun 5, 2007 | 08:51 PM
D4u2s0t's Avatar
doesn't take any skill at all. there's no reason why anybody can't do it themselves. very basic hand tools and the vast, intense knowledge of "righty tighty lefty loosey" is all you need.
Old Jun 5, 2007 | 08:56 PM
whats probably the most tricky thing when installing it? i've looked at the stock and i can't really see how the filter will fit in there? i've heard some people take the fender off, remove front wheel etc.....just want to make sure what i'm gettin myself into
Old Jun 5, 2007 | 08:59 PM
halfj99's Avatar
just dont bang the MAF on stuff or over oil the filter and your good to go
you remove the wheel well lining, so you remove the wheel as well, then rip the old crap out of there , and the new peice will slip through the hole from the bottom, and connect to the pipe in the engine bay
Old Jun 5, 2007 | 09:02 PM
yea, too much oil is not good! is takin off the wheel and wheel lining the easiest way to go at it?
Old Jun 5, 2007 | 09:59 PM
RedEcotecSS's Avatar
it just takes patients bro.
Old Jun 5, 2007 | 10:09 PM
silversccoupe's Avatar
X2!! The hardest part for me was getting the car far enough off the ground to make working on it reasonably comfortable.
Old Jun 5, 2007 | 10:12 PM
M-Dub's Avatar
Yup, get the car off the ground with enough room for you to comfortably be in the wheel well basically, remove the wheel, the inner fender lining, and there isn't to much to it just make sure you are gentle with the MAF sensor, and install the MAF correctly the when reinsalling it! Other than that it is pretty easy!
Old Jun 6, 2007 | 12:42 AM
tkaugh29's Avatar
when i intalled my typhoon i found the hardest part was positioning it. i tightned the L bracked first (which the instructions said to do) but then once that is tight you cant get the opening to fit into the supercharger correctly. overall very easy install. and fitment is perfect, make sure you leave all the bolts loose and tighten the intake onto the supercharger before tightening the l clamp.
Old Jun 11, 2007 | 07:38 PM
well thanks for the tips!! hopefully all will go well, haven't gotten it yet but gettin anxious. will let ya'll know how it goes!
Old Jun 11, 2007 | 08:50 PM
Mikey851's Avatar
It will not be hard, but don't rush though. Be careful with the MAF as said above. Remember, if it doesn't fit, don't force it.
Also, remember to break your lug nuts loose with the car still on the ground, and the same way for tightening them back up.
Old Jun 11, 2007 | 09:43 PM
Brian's07SS's Avatar
I got the same CAI....just bolt it up from the bottom first. THEN connect it to the engine. If you try to do it from the engine down you will have a fitment issue. I tried it that way and the Z bracket was off by like 3-4 inches. There is a nice write up in the HOW-TO section on here. The wheel well lining was the hardest part, for me anyway... I know I missed a few screws puttin it back..
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Sep 25, 2015 06:06 PM
