? on a intense kit
Old Jul 28, 2006 | 07:17 PM
boostedss26's Avatar
? on a intense kit
I have 42.5 lb injectors, 2.8 pulley, intake colder plugs and exhaust. Every time i get on it i get a big cloud of smoke. I'm thinkin it's rich but not sure. Anyone know anything on that?
Old Jul 28, 2006 | 07:19 PM
zinner's Avatar
Moderator Alumni
what color is the smoke?
Old Jul 28, 2006 | 07:21 PM
Black
Old Jul 28, 2006 | 07:22 PM
zinner's Avatar
Moderator Alumni
sounds rich.
Old Jul 28, 2006 | 07:24 PM
Can you do anything with those switches that are in the box?
Old Jul 28, 2006 | 07:32 PM
memphisr24's Avatar
You have the Maf Translator??? What are the switches set at?
zinner's Avatar
Moderator Alumni
I assume you have a maft ?
I don't know much about the maft but I recommend you get hptuners or a customer intense pcm
Old Jul 28, 2006 | 07:34 PM
yeah i have that maf-t > their set at whatever the websight said to put em cand remember off the top of my head
Old Jul 28, 2006 | 07:40 PM
memphisr24's Avatar
Oh so probably this:
1st white switch ON
2nd OFF
3rd OFF
4th OFF
Maf Base: C
Maf WOT: 1
Is that correct? Jeese, with that, I was running extremely lean.....
Old Jul 28, 2006 | 07:42 PM
memphisr24's Avatar
And I have pretty much the same mods as you, stupid 05's.
Old Jul 28, 2006 | 07:44 PM
memphisr24's Avatar
You could lean it out a bit by playing with the two knobs, but I wouldn't touch them unless you had either a wideband gauge or dyno to somehow see what your a/f ratios are.
Old Jul 28, 2006 | 07:48 PM
ok. Thanks. I figured since it's boosted it will blow a little black but it's more then i thought it would be.
i got an 06 if that matters any
Old Jul 28, 2006 | 07:49 PM
memphisr24's Avatar
Yeah, just look on the back of the cover of the maf translator. It should have a list of settings correct? Don't change it by more than one click if you do change it!
Old Jul 28, 2006 | 07:50 PM
memphisr24's Avatar
Well the 05's, well at least my 05 runs leaner than 06's and was slower than my friends stock 06 when I was stock. Not by much, but it was noticeable.
thewafflesareburnt
Sep 30, 2015 02:29 AM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
