intense pcm case learn?
Old Jul 11, 2006 | 06:20 PM
cblt12's Avatar
well i have searched and could not find anything about this... i was reading on intese's website and under the pcm section is says that after a mail order pcm is installed that there must be a "Crankshaft Position Variation Learn procedure" done... i was wondering if anyone on here had to have this done or if there is something that i am missing.
http://intense-racing.com/
Old Jul 11, 2006 | 07:10 PM
BooSSted's Avatar
Yes you need it done. Take the car to the dealer and they will do it.
Old Jul 11, 2006 | 09:05 PM
cblt12's Avatar
will it be fine to drive to the dealer to get it done?
Old Jul 11, 2006 | 09:11 PM
Ljavy17's Avatar
its not that easy, most dealers will not do it, since u only want a case learn and not full tune, maybe theyll erase your current setting so you have to be clear to them about your car being custom and such so most wont touch a custom car.
Old Jul 11, 2006 | 09:12 PM
Ljavy17's Avatar
oh and your looking at around 100 dlls for it, maybe slightly less.
Old Jul 11, 2006 | 09:18 PM
srt-killer's Avatar
Yes its fine to drive. Just don't go over 1/2 throtle cause then it will cause your car to pull timming and with the crankshaft positioning sesor off It could pull too much timing, because it's not compesating for the timming changes of the new PCM.
cblt12's Avatar
thanx a lot... so pretty much i should call around to a bunch of dealers?
Old Jul 11, 2006 | 11:12 PM
BooSSted's Avatar
Just go to the dealer, tell them you have a new ECU in the car and you need the crankshaft position relearn procedure done. It will take them about 10-20 minutes. I was charged a half hour labor. It's a very easy process and I can't see why any of them would decline to do it.
Old Jul 11, 2006 | 11:21 PM
dstinsman56's Avatar
because when they ask you why you have a new computer in your car you just stand there quietly looking like a jackass for not knowing why.
this happened to me already
Old Jul 18, 2006 | 04:47 AM
Psykostevo's Avatar
I do case learns on my own cars. I work at a dealership and I sneak off with the GM Tech 2, and you have to have a CANdi Module on it too. Just select your year, our car is an "A" when the next question pops up, and then we are the 2.0L LSJ. Now you go to drivetrain, and then locate the Variable Case position learn or something like that. I could almost to is in mysleep. It is super super easy! You just need the Tech 2 AND the CANdi module.
Once you get to this menu, it takes like 5 seconds to do the case learn. You turn the car to on, set the parking brake push the brake pedal, start the car, rev the car til it hits the limiter, and back off and turn off and unplug the scanner.
Don't take it to a Chevy dealer, try a pontiac dealer so they won't care about why you did anything to your car.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
