Intense Stage 4-Switch to GM stage2...
Check it out, stage II bring you to 246 horsepower, but not to the wheels, your intense stage 4 bring you to 244 hp to the wheels, but I understand the driving ability in the weather. I say you keep your stage 4 and just install gm stage II until the weather clears up
yea i thought of using the bigger pulley as well, what size would be good? i have a 2.5 here that im afraid to use even in the summer with the correct tune. But i know its not the intense tune alone, but basically every tune, im making more boost thus need re-tune or bigger pulley.
I guess i got scared after the bad batch of gas i got right after installation of the kit and had serious KR issues.
So 2.8-2.9? which would put me around 16psi?
from what I understand, most of the time your knock sensors will pick up quite a bit of knock before it becomes actually audible to you.
I think if you can actually hear it....you might have a more serious problem than just a little knock.
At the times its audible i cut off immediately, its only happend twice since ive had the kit, and both times i wasnt paying attention to the guage, so im not sure what it was reading...
