interceptor gauge questions
Old Mar 25, 2009 | 01:32 PM
06cobalt racer's Avatar
ok i know that the interceptor gauge is an amazing thing. i was on ott website earlier looking at them. first question, what is the lc-1 thing? is it needed to have the gauge? also how do you install on of these?
Old Mar 25, 2009 | 01:34 PM
stoon_cobalt_colby's Avatar
the interceptor gauge is pretty simply to install u just straight plug it in so easy to set up isnt much of a problem but im not sure aobut lc-1 thing i beileve it could be to monitor Air/fuel ratio i could be wrong tho i just got a interceptor and aem wideband
Old Mar 25, 2009 | 01:38 PM
ShortStack's Avatar
Your beating around teh bush a little...
The lc-1 is a wideband controller, not the entire gauge setup...
you use the lc-1, which reads the wideband.. then you can read your actual afr on the interceptor... just like you can any other setting... The afr you can read without the wideband is pretty much useless...
Old Mar 25, 2009 | 01:39 PM
NGASales's Avatar
PM Sent
A lot of our customers go with the AEM Uego and Interceptor
Old Mar 25, 2009 | 02:12 PM
Originally Posted by NGASales
PM Sent
thats what i went with happy with love the setup looks great
Old Mar 25, 2009 | 02:45 PM
the interceptor is the gauge, i know that. the aem uego is what exactly? just wideband o2 sensor? tried looking for it but only found something that comes with the o2 sensor and a gauge. would i need to run 2 seperate gauges?
Old Mar 25, 2009 | 02:52 PM
ShortStack's Avatar
No..
Old Mar 25, 2009 | 02:58 PM
Originally Posted by ShortStack
No..
ok... then what am i missing. can you help?
Old Mar 25, 2009 | 05:51 PM
Jrhdpaintball's Avatar
the interceptor has 2 seperate options for analog 1 and 2... you can use the lc-1 wideband to send the info to the interceptor gauge and monitor on the analog 1 option... soo that way you can have just one gauge doing the same that 2 would do...
Old Mar 26, 2009 | 09:22 AM
ok sounds good. one more question. with the interceptor does it read the a/f ratio at all without the lc-1? i am thinking i might just get the interceptor and then later get the lc-1.
Old Mar 26, 2009 | 09:35 AM
yea you could get the interceptor gauge... then later buy the lc-1 gauge and wire it to the interceptor to monitor afr as well... whichever you like... i moniter IAT-2 and knock retard, and a few other things with my interceptor... so adding afr to it... doesnt give me enough options so i like having the extra gauge, but my personal preferance...
Old Mar 26, 2009 | 09:57 AM
ShortStack's Avatar
Do not read the AFR through the interceptor without a wideband.. i have already said this.
That is your commanded AFR. You want to read your actual wideband AFR... because sometimes, the commanded is no where NEAR actual.
Old Apr 20, 2009 | 01:15 AM
Flatgod's Avatar
I have the innovative lc-1 wideband controller hooked up to my interceptor, but i'm confused about the whole setup with the slope and intercept setting in the guage. I have it working and giving afr #'s but i'm not sure if they are the right #'s. Does anyone else have this exact setup? If so what did you use for the slope and intercept #'s for it?
Old Apr 20, 2009 | 12:10 PM
HOT CARLS SS's Avatar
How do you hook up the LC1 to read air/fuel on the interceptor analog 1??
Old Apr 20, 2009 | 12:12 PM
RuSSo-29's Avatar
I'm selling my 2x Interecptors.... I have a F/S thread around here some where. Your welcome to PM me an offer....
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
Sep 27, 2015 08:53 PM
