interceptor params that work for our 2.0 sc
which paramiters works for our cars?will someone please del the ones that we cant use?
or that do not work properly?
Supported Parameters and Functions by Manufacturer
General Motors (non-CAN vehicles) PT series gauges:
1. INTAKE AIR- Intake Air Temperature - **
2. COOLANT TEMP- Engine Coolant Temperature **
3. TRANS TEMP 1- Transmission Temperature for automatic gas vehicles
4. TRANS TEMP 2- Trans temp for some vehicles made from 94-97.
4. RPM- engine Revolutions Per Minute **
5. MAF SENSOR LB/M- Mass Air Flow (lbs/min) **
6. MAF FREQUENCY- raw Mass Air Flow sensor output (frequency)
7. MAF FREQUENCY 2- raw MAF sensor output for the Cobalt SS and Redline
8. MAP SENSOR- Manifold Air Pressure (kPa) **
9. BOOST Intake vacuum/boost displayed in inHg/PSI. Corrected by altitude entry or barometer**
9. THROTTLE POS. PCT- Throttle Position percentage (0-100%)
10. THROTTLE VOLTS- Throttle Position sensor output (0-5 volts)
11. MILES PER HOUR- Miles Per Hour **
12. KNOCK RETARD- Knock Retard (degrees) for most GM vehicles
13. KNOCK RETARD 2- used for KR value of 94-97 LT1s and some 96/97 V8s.
14. KNOCK RETARD 3- used for knock retard value of the Cobalt SS SC and Redline
15. IGNITION ADVANCE- ignition timing advance
16. PULSE WIDTH- injector #1 pulse width (4&6 cylinder engines)
17. SHORT TRIM B1-short term fuel trim bank#1
18. SHORT TRIM B2-short term fuel trim bank#2
19. LONG TRIM B1-long term fuel trim bank#1
20. LONG TRIM B2-long term fuel trim bank#2
21. OXYGEN SENSOR B1-O2 bank 1 sensor 1 in millivolts
22. OXYGEN SENSOR B2-O2 bank 2 sensor 1 in millivolts
23. OXYGEN SENSOR alternate O2 sensor parameter, rarely supported.
24. RUN TIME MINS- engine run time is tenths of seconds since last engine start **
25. BATTERY VOLTAGE- Alternator/battery output voltage **
26. IAC POSITION- Idle Air Control counts (position of Idle Air Control valve)
27. PULSE WIDTH B1-injector Pulse Width for bank 1 (8 cylinder engines)
28. PULSE WIDTH B2-injector Pulse Width for bank 2 (8 cylinder engines)
29. ENGINE LOAD- calculated Engine Load (0-100%) **
30. ENGINE OIL PRESSURE (some 8 cylinder engines) **
31. INTAKE AIR 2 Intake Air Temp. downstream of intercooler (some supercharged applications such as the
Cobalt SS, Ion Redline).
32. TRANS TEMP AL- Allison transmission temp, Duramax and Workhorse
33. TORQUE CONVERTER SLIP AL- Allison transmission converter slip, Duramax and Workhorse
34. TQ TO TRANS AL- Engine torque delivered to trans, Duramax and Workhorse
35. INJECTOR RAIL PRESSURE DESIRED DM- Duramax
36. INJECTOR RAIL PRESSURE ACTUAL DM- Duramax
37. THROTTLE PCT DM- Throttle percentage- Duramax
38. THROTTLE VOLTS DM- Throttle sensor voltage- Duramax
39. FUEL LEVEL DM- Duramax
40. INJECTOR FLOW RATE DM- Duramax
41. Desired Turbo Vane Position- 2004+ Duramax
42. Actual Turbo Vane Position- 2004+ Duramax
43. Pilot Injector Pulse Width- pilot injector pulse width in msec. - Duramax
44. Main Injector Pulse Width- main injector pulse width in msec. - Duramax
45. Pilot Injector Timing- in degrees - Duramax
46. Main Injector Timing- in degrees - Duramax
47. Pilot Injector Fuel Rate- mm^3 - Duramax
48. Main Injector Fuel Rate- mm^3 - Duramax
49. Miles Per Gallon 1- instantaneous fuel economy for gas vehicles
50. Miles Per Gallon 2- instantaneous fuel economy for diesel vehicles
51. HP 1- Calculated net horsepower for gasoline vehicles
52. HP 2- Calculated net horsepower for diesel vehicles
53. Analog 1 analog input #1.
54. Analog 2 analog input #2
55. TOTAL MISFIRES- Total misfires of all cylinders. Resets every minute.
56. BAROMETRIC PRESSURE- limited support on standard GM vehicles, DM support
57. PITCH H2 Hummer support indicates the angle of inclination of the vehicle.
58. CURRENT GEAR- Current gear of the transmission
59. TORQUE- Calculated torque from engine to transmission
60. SHIFT TIME- time (msec) for last shift to occure.
61. TORQUE CONVERTER SLIP Amount of slip allowed by torque converter
62. TORQUE CONVERTER STATUS- Indicates whether torque converter is locked (L) or unlocked (UL)
**These standard GM parameters also are supported by the Duramax diesel
Bi-directional controls:
1. Fan 1-3 control
2. PCM (fuel trim) reset
3. CASE (Crank Angle Sensor Error) Re- Learn
General Motors (CAN vehicles) CN series gauges:
3. TRANS TEMP 1- Transmission Temperature for automatic vehicles
7. DI FUEL PRESSURE Direct injection fuel pressure (vehicle must have direct injection)
10. THROTTLE POS. PCT- Throttle Position percentage - actual
11. ABSOLUTE THROTTLE POSITION will read throttle position from 0-100%
12. MILES PER HOUR- Miles Per Hour
13. KNOCK RETARD- Knock Retard (degrees) for most GM vehicles
14. IGNITION ADVANCE- ignition timing advance
15. PULSE WIDTH- injector #1 pulse width
16. SHORT TRIM B1-short term fuel trim bank#1
17. SHORT TRIM B2-short term fuel trim bank#2
18. LONG TRIM B1-long term fuel trim bank#1
19. LONG TRIM B2-long term fuel trim bank#2
20. O2 SENSOR B1S1-O2 bank 1 sensor1 in millivolts
21. O2 SENSOR B2S1-O2 bank 2 sensor1 in millivolts
22. O2 SENSOR B1S2-O2 bank 1 sensor 2 in millivolts
23. O2 SENSOR B2S2-O2 bank 2 sensor 2 in millivolts
26. CURRENT GEAR- The current gear of an automatic transmission.
29. INJECTOR DUTY CYCLE- 0-100%
30. ENGINE LOAD- calculated Engine Load (0-100%)
31. ENGINE OIL PRESSURE (not supported by all vehicles)
32. ENGINE OIL TEMPERATURE Engine oil temp.
33. INTAKE AIR 2 Intake Air Temp. downstream of intercooler (some supercharged applications such
as the Cobalt SS, Solstice GTP, Saturn Sky).
34. TOTAL MISFIRES- Total misfires of all cylinders. Resets every minute
35. Miles Per Gallon 1- instantaneous fuel economy for gas vehicles
36. BAROMETRIC PRESSURE- Displays atmospheric pressure. All vehicles may not support this.
37. HP - Calculated net horsepower
38. TRQ RDCT RTRD Spark retard due to torque management ( automatics trans)
39. DELIVERED TORQUE Calculated torque delivered from engine to transmission (automatic trans)
40. TRQ TRAC CNTL - Desired torque from traction control system (auto trans)
41. TC SLP SPD RPM Torque converter slip (RPM) (auto trans)
42. TRANS IN RPM RPM of input shaft to transmission (auto trans)
43. TRANS OUT RPM RPM of transmission output shaft (auto trans)
44. NON DRV SPEED Speed of non-driven wheel (mph)
45. TCC STATUS Indicates UL or L (unlocked /locked) depending on the state of the Torque
Converter Clutch
46. FUEL STATUS Displays Open or Closed to indicate open or closed loop fueling.
47. FUEL LEVEL Gallons of fuel remaining in tank.
48. Cat Temp1 Calculated catalytic converter #1 temperature (calced by the cars PCM)
49. Cat Temp2 Calculated catalytic converter #2 temperature (calced by the cars PCM)
48. Analog 1 analog input #1.
49. Analog 2 analog input #2
50. COMMANDED A/F Commanded air/fuel ratio by PCM.
51. COMMANDED LAMBDA Commanded Lambda (a different way of measuring A/F ratio. Lambda
= 14.7/actual A/F ratio. Therefore a value greater than 1 is rich, less is lean.
52. LAMBDA Actual Lambda (only available on vehicles with factory wideband sensor)
53. A/F RATIO Actual A/F ratio (only available on vehicles with factory wideband sensor)
54. SENSOR CURRENT Current draw of wideband O2 sensor (only available on vehicles with factory
wideband sensor)
4. Fan 1-3 control
5. PCM (fuel trim) reset
6. CASE (Crank Angle Sensor Error) Re- Learn
Notes:
g suffix, such as Intake Air g simply means that this is a generic parameter and can be displayed on any
CAN bus vehicle except Honda.
1. Fan 1-3 control
Converter Clutch
wideband sensor)
4. Fan 1-3 control
Notes:
since i cant edit my 1st post, I edited the ones that i have tried.
9. THROTTLE POS. PCT- Throttle Position percentage (0-100%) - you have to calibrate i think
17. SHORT TRIM B1-short term fuel trim bank#1 -not sure
18. SHORT TRIM B2-short term fuel trim bank#2 -not sure
19. LONG TRIM B1-long term fuel trim bank#1 -not sure
20. LONG TRIM B2-long term fuel trim bank#2 -not sure
25. BATTERY VOLTAGE- Alternator/battery output voltage ** -not sure
26. IAC POSITION- Idle Air Control counts (position of Idle Air Control valve) -not sure
29. ENGINE LOAD- calculated Engine Load (0-100%) ** -not sure if accurate
51. HP 1- Calculated net horsepower for gasoline vehicles -not accurate
1. Fan 1-3 control
Converter Clutch
wideband sensor)
4. Fan 1-3 control
Notes:
1. Fan 1-3 control
Converter Clutch
wideband sensor)
4. Fan 1-3 control
Notes:
Also, I had to look this up... parameter with B1 and B2 (Bank 1 and Bank 2) are for V-type cylinder arrangment motors.
Since we have 4 in-line then we only use B1 (Bank 1 always includes cylinder 1).
Pike
Pike
Sep 28, 2015 12:51 PM
