Interceptor question
so i recently bought and hooked up my interceptor gauge/wideband to start tuning. and i've noticed that at WOT my gauge pegs 10.2 and stays there. just out of curiousity, do i maybe have a wiring issue or is wiring correct but gauge only registers down to 10.2? i have hp tuners and was gonna start tuning but just wanted to make sure gauge was reading properly before i went ahead and started messing around with AFR's
Does it act normal just cruising or idling? 14.7 swaying lean and rich a bit? if so its probably fine. Drop you wot timing by 5-10*, lean out top end a point, and see if it leans out...
mods include zzp stage 3 sc kit, option b with dual pass, zzp headers/dp combo with tsudo exhuast. yes SC it acts normal at cruising and moderate throttle, but as soon as i hit the gas, bam right to 10.2
