interceptor question
Old Mar 9, 2008 | 12:22 AM
outtamymind's Avatar
this is what the jumper will look like, but they do come in a multitued of colors.
Old Mar 9, 2008 | 12:45 AM
Joeyavhu's Avatar
What exactly do they do, just so I know what I am taking off. But yea, those are what they look like.
Old Mar 9, 2008 | 12:48 AM
long definition short they tell the little onboard computer which setting to use. and trust me take it off and try it out and i can almost gaurantee you that it will work as it should after that. if it doesn't then there is something else wrong.
Old Mar 9, 2008 | 12:50 AM
Joeyavhu's Avatar
Okay. I will give it a shot tomorrow. Hopefully this works. This is probably something that I should not have waited a year to do. Lol
Old Mar 9, 2008 | 12:53 AM
lol. ya give it a shot. like i said as long as you are using the correct empty fuse slot, take the jumper off and have everything crimped and connected properly it should work fine. if not then i can't really help you anymore from here. mind you beverly hills sounds kinda nice this time of year
Old Mar 9, 2008 | 12:56 AM
Joeyavhu's Avatar
Yea, down here is Florida it was a chilling 82 degrees today... If the gulf was a little warmer I probably would have went jetskiing. Lol. I remember the cold though from when I lived up in New York, 2 blizzard
Anyway, I will connect the interceptor straight to the battery first, to test and make sure it works, then once it works (hopefully) I will connect it to the fuse I have set up. I will keep you posted. Thanks for the help, by the way.
Old Mar 9, 2008 | 01:01 AM
no worries. thats what this site is for right. and i would try the fuse panel first but that is just me.
Old Mar 9, 2008 | 02:17 PM
stonny9's Avatar
add a fuse actually adds a power wire into that fuse that you "replace"
Old Mar 9, 2008 | 02:20 PM
Coblt ss super's Avatar
subscribed
Old Mar 9, 2008 | 03:02 PM
Joeyavhu's Avatar
Okay. Cool. That video helped with were to stick in the Add-A-Fuse. I am about to go work on it now. Hopefully...
Old Mar 9, 2008 | 03:24 PM
  #36
stonny9's Avatar
yeah i learned the hard way. Ran it through the firewall then had the remove it because i had to diagnos an elec problem. A fellow member told me about the fuse panel inside the car. Took a whole 10 mins to reinstall the interceptor and rund the power.
Old Mar 9, 2008 | 04:28 PM
  #37
Joeyavhu's Avatar
Thank you guys for all the help. After 1 year, it finally works. Lol. It turns out it was that little red jumper that was stopping it the whole time. I took that off, and since then it has been running like it is supposed to.
Old Mar 9, 2008 | 04:47 PM
  #38
ya i thought that's what it was. glad that its working properly for ya now.
Old Mar 9, 2008 | 04:50 PM
  #39
yeah, i have to unplug and plug in my OBD2 plug to get it to come on all the time. I am not running no power wire becuase im not sure where to run it. So ive been running it like this for now. but how can i get power to it which is on my C/A Steering wheel pod
Old Mar 9, 2008 | 05:06 PM
  #40
same way just run the power wire up behind the steering column.
Old Mar 9, 2008 | 05:08 PM
  #41
Joeyavhu's Avatar
Lol.. Make sure you take off that little jumper if you havent already. What does that piece even do, or supposed to do?
Old Mar 9, 2008 | 05:09 PM
  #42
its to switch between using power from the obdII and direct power but they worded it backwards in the manual.
Old Mar 9, 2008 | 05:10 PM
  #43
Joeyavhu's Avatar
Ohh.. Okay. Well then, Im just excited that it works right now. Lol
Old Mar 9, 2008 | 05:11 PM
  #44
hahaha i bet you are. the first 2 that i installed for some buddy's of mine took me 2 days to completely figure out all the little qwerks the interceptors have. like how they are picky about their power source and that little jumper.
Old Mar 9, 2008 | 05:13 PM
  #45
Joeyavhu's Avatar
Yea. I now see that. It took me a little to figure out how to get the Cyclic scan to work. The first time I went to set it, I ignored where it said screen 1 / field 1 and such and was wondering why I couldnt get out of any of the menus. Lol
Old Mar 9, 2008 | 05:15 PM
  #46
ok so wat do i need to add that fuse into slot 22?
Old Mar 9, 2008 | 05:35 PM
  #47
you need a mini make a fuse. you can get them at any parts store. and attach your red power wire to that and plug it in. and thats that.
Old Mar 9, 2008 | 05:36 PM
  #48
ok, imma go tomorrow and get one, i cant today since im at work then gotta pick up my baby sister, but ill try this tomorrow
Old Mar 9, 2008 | 05:38 PM
  #49
just make sure you use empty fuse slot 22. there is a little diaghram on the panel that you pull off that shows you the location of it.
Old Mar 9, 2008 | 05:41 PM
  #50
ok, will do, also my girlfriend gave me interior LED kits for under the seats, can i use another empty slot for those? if there is anymore
