interceptor question. need help
Old Jul 28, 2009 | 08:21 AM
hawkeyez's Avatar
I just installed my interceptor gauge. How do i get the gauge to power up when i turn the car on? i hate unplugging it every time to get it to turn on. the gauge will power down when i turn the car off. its plugged into the obdII port like it is supposed to be and out of the red, green and white wires i ran a seperate power wire is run from the red wire to the fuse box. Im confused. Please help
Old Jul 28, 2009 | 11:07 AM
Angel's Avatar
Did you pull the jumper pin on the back of the interceptor?
Old Jul 28, 2009 | 11:26 AM
06cobalt racer's Avatar
yeah you have to pull the red jumper on the back. i wired the red power wire to my boost gauge. works great
Old Jul 28, 2009 | 11:39 AM
falke401's Avatar
I have the red wire wired into my sunroof fuse with the jumper off and works fine.
Old Jul 28, 2009 | 11:40 AM
falke401's Avatar
Old Jul 28, 2009 | 12:28 PM
Tank07's Avatar
pull the red jumper on the back.........and make sure that the power line you ran is switched to the ignition (i.e. sunroof fuse) i tapped my sunroof fuse and have had no problems
Old Jul 29, 2009 | 05:52 AM
hawkeyez's Avatar
Interceptor jumper?
Do I just have to pull the red cap off? Do ya do anything with the two prongs that were under the red cap. I pulled the red cap off and there were two prongs?????
Old Jul 29, 2009 | 06:08 AM
yeah just pull the red cap off and leave the prongs alone and you will be fine
Old Jul 29, 2009 | 07:23 AM
hawkeyez's Avatar
Ok I'll try that today.
Old Jul 29, 2009 | 03:55 PM
let us know
Old Jul 29, 2009 | 04:53 PM
hawkeyez's Avatar
where is the sunroof fuse???
Old Jul 29, 2009 | 04:54 PM
flash13brandon's Avatar
Just tap into the red boost gauge wire. Very simple.
Old Jul 29, 2009 | 06:16 PM
hawkeyez's Avatar
The interceptor gauge is now working. Powers up and powers down with no problems. Thanks for your help guys. Whats some good things to watch for??
Old Jul 29, 2009 | 06:21 PM
rico's Avatar
knock and iat2s
Old Jul 30, 2009 | 03:12 AM
hawkeyez's Avatar
What shoud the numbers be for iat2's and knock?????????????? Im running gm Stg 2,, GMPP exhaust and header, injen cai, ZZP 3in catless dp, ZZP heat exchanger with reg radiator.
Old Jul 30, 2009 | 12:15 PM
iat2's will vary depending on outside temp, cooling mods, others. as for mine with my mods, it is between 15-20 degrees warmer then iat1 temps. that is while cruising at least
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
nathan112i
Sep 30, 2015 07:12 PM
Bohb
Sep 27, 2015 09:11 PM
bustaSS
Sep 3, 2015 09:33 PM
