Interceptor Scan Gauge Hp reading accurate or not?
Old Oct 8, 2011 | 06:01 PM
DCOBALTSS's Avatar
So im a 2.4 cobalt supercharged with k&n intake and 2.9 pulley catback 2.5inch magnaflow custom
My reading in full wot 4th gear goes to 366hp approx the best i had..
Is that accurate or really not??
thanks
Old Oct 8, 2011 | 07:18 PM
395 plus's Avatar
No its not accurate its not set for the weight of your vehicle. No way your making 366hp.
Old Oct 8, 2011 | 07:19 PM
TommyP's Avatar
AWD > FWD
Read the manual for your interceptor, it says you have to enter some kind of correction factor to make it closer to accurate, it'll never be completely accurate though.
Old Oct 8, 2011 | 11:36 PM
xxxxsh4d0wxxxx's Avatar
You're ******* shitting me right...............
Old Oct 9, 2011 | 12:07 AM
DCOBALTSS's Avatar
so good to be true :P
Old Oct 9, 2011 | 12:14 AM
thedubsack85's Avatar
Did you enter you YOUR car's weight after having it weighed without you in it and also factored in your weight+the car's weight? My interceptor's were just about spot on once i factored in weight, It said i had about 240-255ish hp from 6-7k And my IRL pulled on other IRLS that had more work done!
Old Oct 10, 2011 | 12:59 AM
insylem's Avatar
Nowhere did I see in the instructions nor my gauge where I can enter my vehical's weight.
However, the Correction factor applies both to the HP and the MPG settings. Leave the
MPG (instant not average) displayed for several gas tanks and monitor your actualy gas
milage, and what the interceptor says your getting on the average setting. (Interceptor only averages / computes averge when instant is displayed ) Then use this formual
Correction Factor = 100*(Actual Gas Milage / Reported Gas Milage by intercetpros average setting)
Example:
You compute based on Milage, and gallons of gas top offs that you get 30mpg
Interceptor average says you get 60mpg average
30/60 = 0.5
0.5 * 100 = 50
You Enter
050 for your correction factor.
Correct your MPG and it should give you fairly close to what your HP is. Keep in mind even dynos don't have accurate HP readouts. Otherwise the
same car would read the same HP on each dyno.
The correction factor is basicly a multiplyer that runs by %
It multiplies your MPG and your HP by this same number.
100 = 100% = * 1
50 = 50% = * 0.5
Old Oct 10, 2011 | 09:53 AM
There has to be a weight setting, I remember setting the weight on mine after having my car weighed at a recycling plant! Over 3 years ago!
Old Oct 10, 2011 | 12:06 PM
insylem's Avatar
Maybe an older version, but I checked out the newer version of the manuals for both the CAN(i)bus and the PT Bus gauges. Neither mention weight at all.
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
