Question
Old Oct 10, 2011 | 06:30 AM
insylem's Avatar
Question
I just baught the intake spacer for the LSJ Intake Manifold.
It comes with:
Phenolic spacer
(2) intake manifold gaskets
1 set of longer intake bolts
3 IC pump spacers
Ok
Ok Phenolic Spacer, Ok thats self explanitory
2 Intake manifold gaskets, 1 for each side of the spacer that makes since.
Set of longer bolts. of course, your going through more material
3 IC Pump spacers... What are these for?
Old Oct 10, 2011 | 07:53 AM
blake05SS's Avatar
it pitches the intercooler bracket since the IM will be pitched at a different angle and will stick out another 1/4 inch
Old Oct 10, 2011 | 07:57 AM
zfissette's Avatar
yup, if you look at the bottom of the intake manifold theres a bolt there, once you put the spacer in it wont line up anymore so while you have the intake off, unbolt the pump bracket and put one metal spacer behind each bolt hole. remember that all the bolts in this kit are lengthened correctly so make sure you use the right ones in the right holes.
Old Oct 10, 2011 | 02:35 PM
Boosted05's Avatar
I'd love to know what goes where, i re used all my stock ones except the 2 long ones that replace the studs, as i had 4 reg head bolts, and 1 extra alan head.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
