Interceptor shift lights?????
Old Jul 31, 2009 | 04:02 AM
hawkeyez's Avatar
I was wondering how you set up the shift lights on the interceptor gauge? I read the manual but can't seem to get them to work. Please help?
Old Jul 31, 2009 | 04:09 AM
HB_SS/TC's Avatar
you got to make sure annunciator is turned on
Old Jul 31, 2009 | 01:44 PM
hawkeyez's Avatar
It is turned on. then you set it under rpm's??
Old Jul 31, 2009 | 01:47 PM
ssyellow's Avatar
let me find the thread... I did like a step by step write up lol
Old Jul 31, 2009 | 01:51 PM
DeepBlack SS's Avatar
you have to set it over rpms and set the number to where you want the light to come on
Old Jul 31, 2009 | 02:09 PM
ssyellow's Avatar
I cant find it for the life of me .
Old Jul 31, 2009 | 02:18 PM
Tazmanian_Dvl's Avatar
Hit both buttons on face of the gauge at the same time then the main menu pops up. Next make sure in the setup menu you have RPM's selected for one of the perameters the gauge is supposed to monitor. Next scroll down the main menu until annunciator is highlightes and select it. it will ask you to select what number you want it to come on at, next screen I think will give you a list of perameters to select from (RPM, IAT1, IAT2, etc. basically what you selected in the setup menu) select RPM and then the next screen will ask you over or under. You want to select over and then exit and it should restart the gauge. This might not be exact but it should get you pretty close. Let me know if you need anything else...
Old Jul 31, 2009 | 02:20 PM
ssyellow's Avatar
yay he wrote it up I did one and it was like 5 times as big as yours lol. anyways what he said but you might need to turn on the annunciator on after you do that.
Old Jul 31, 2009 | 02:25 PM
hawkeyez's Avatar
Ok thanks for your help. Ill go and try it and ill let ya know how it works.
Old Jul 31, 2009 | 02:32 PM
Once you're done setting up the annunciator it will automatically turn on. Also FYI every time you go into setup and change the perameters you're viewing you will have to setup the annunciator again...
Old Jul 31, 2009 | 05:35 PM
stoon_cobalt_colby's Avatar
thanks man worked great now got shift light what should i set it to in rpm? i have set at 6500
Old Jul 31, 2009 | 05:39 PM
hawkeyez's Avatar
im curious to know to.
ssyellow's Avatar
depends on what you have. whats your rev limiter at?
Old Jul 31, 2009 | 05:41 PM
7000
Old Jul 31, 2009 | 05:44 PM
hawkeyez's Avatar
7000 here to!!!!!!!!
Old Jul 31, 2009 | 05:47 PM
whats ur mod list like?
Old Jul 31, 2009 | 05:49 PM
I personally set it a few hundred RPM's below my rev limiter because by the time the light comes on and you get to shifting you're right at your rev limiter. If you're at 7000 I"d say set it at 6700 or so and tweek it based on how fast you shift. I have dual interceptors so I have one set at 500 RPM's below and the other at 250 RPM's below so it shows in stages...
Old Jul 31, 2009 | 05:59 PM
i set it to 6600 rpm for good luck
Old Jul 31, 2009 | 06:34 PM
hawkeyez's Avatar
I hope i can get mine to work!!!!!!!!!!
Old Jul 31, 2009 | 06:39 PM
ssyellow's Avatar
its not hard ask for more help if you want and I will write up my 5 paragraph description again lol. I found it out without any help and you can also . play around with it and set it at low rpms so you dont rev the **** out of your engine when testing it lol. I have my light set at 6,500 and its on ABOVE.
Old Jul 31, 2009 | 09:08 PM
Gene Culley's Avatar
Talking
My rev limit is 7000 and I have it on 6700 and it is just right.
Old Jul 31, 2009 | 10:32 PM
yea if your rev limit is 7000 you don't want it to come on at 7000 because by then it's too late. You want it just a bit before so you have time to react to it and shift...
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
nathan112i
Sep 30, 2015 07:12 PM
2009blackSS
Sep 30, 2015 05:57 PM
