intercooler
Old Apr 20, 2006 | 10:12 AM
chubbs's Avatar
intercooler
i havent exactly looked thru the previous posts but i want to know is how come i have yet to see anyone with an intercooler. as far as i knew i thought anything with boost could use a FMIC(front mount). i have seen cars with them before and they were supercharged. and i thought the ion redline came with one. so how come no one has 1? if im wrong someone help me out.
Old Apr 20, 2006 | 10:14 AM
theTITESTride's Avatar
if your talking about a Cobalt SS/SC, it does come with an intercooler behind the bottom grill....are you asking about something else??
Old Apr 20, 2006 | 10:17 AM
chubbs's Avatar
yea i was talkin about the ss/sc i thought they didnt come with a FMIC. hmmm guess i never noticed. o and btw i dont one yet which is why i wouldnt know. and everyone around here either has a honda eclipse or a stang. anyway how come i have yet to see a upgrade for one tho?
Old Apr 20, 2006 | 10:20 AM
well I know the cobalt SS/SC comes with an intercooler, as for upgrades though, I have not looked into that yet. I'm pretty sure the stock one will hold up till a reasonable amount of Hp that you put in the car.
Old Apr 20, 2006 | 10:27 AM
cobss187's Avatar
yeah same here i have set to see an intercooler upgrade for this car.... i dont even see anything on cobaltaddiction and they have most of the upgrade needs except for gm stuff
Old Apr 20, 2006 | 10:31 AM
p7x's Avatar
p7x
intercooler I think better known as the heat exchanger doesnt have any upgrades to date I would be very interested if there is one. The only thing you could do now is move the intercooler infront of the rad and air condenser instead of its stock position in between.
Old Apr 20, 2006 | 10:33 AM
BLKSS's Avatar
We should start seeing upgrades soon. The car is still new in the aftermarket world.
Old Apr 20, 2006 | 12:11 PM
03gobluecobra's Avatar
The intercooler is located under the blower.
You are referring to the heat exchanger, which is a front mount. All cars have them. You won't gain any hp by upgrading it, you can only help to fight heat soak, and keep the coolant temps lower for a longer time. There aren't any upgrades available yet, because I have yet to see cars overheating. When cobra's started overheating, people then started upgrading the intercoolers.
Old Apr 20, 2006 | 02:39 PM
chubbs's Avatar
you dont necessarily need to have ur car overheat to start upgrading. you upgrade for better performance or better numbers. some people downgrade for better numbers. look at the subarus who move it from top mount to front mount for better forced air induc to the IC. and then they go like a size wider or longer. w.e. either way thats the point really. well unless you were only talkin about the heat exchanger
Old Apr 20, 2006 | 03:57 PM
BooSSted's Avatar
Our cars have a Water - Air intercooler, that's why you don't see the big front mount intercooler. It is located under the blower and is part of the intake manifold. If you want to change it your going to need to fab a whole new intake manifold.
Old Apr 20, 2006 | 06:29 PM
CynicX's Avatar
only because the top mount can only handle so much and there isnt much room to go big enough for some of the turbos people are running. So they move them in front so they can benefit from the increase size....of course this has benefits and drawbacks. It wont get heat soaked while at idle since the engine isnt under it anymore, but the longer piping will increase turbo lag. Two things you guys will never have to worry about....
I'm running the stock TD04 turbo and if I were to goto a larger intercooler I would lose performance. So I imagine maybe the Cobalt doesnt push enough PSI to warrant a larger intercooler and a bigger one would only hurt performance.
Old Apr 24, 2006 | 02:01 AM
cobss187's Avatar
your my new best friend... i knew it was an air to water ****, i didnt know where it was mounted tho
Old Apr 24, 2006 | 03:13 AM
PuSha050's Avatar
while reading the thread i swore if some1 didnt say this i was gonna go jump out my window. thankfully BooSSted you saved my life
(j/k on the jumping out of the window---i like being alive) haha
Old Apr 24, 2006 | 03:45 AM
Cobalt_Supercharged's Avatar
The best way to upgrade the IC setup is create a chiller box for the IC liquid.
GM also experimented with having the liquid make multiple passes through the IC before returning to the aftercooler(the heat exchanger up front). They found a 2 pass set up to be the best. Stock set up is a single pass.
Old Apr 25, 2006 | 06:06 AM
cavy9psi's Avatar
see i wanna try something i love custom...i want to do a front mount (since a turbo is pushing the boost a supercharger is pulling, but its still 12psi) so....mount a font mount where its saposed to be. Then pipe from the throttle body to one side of the FMIC. then finally on the opposite side an intake that goes somewhere idn) dyno stock then dyno an intake then dyno with that set up see if it gains or losses. its still cooling the air, also you can intercooler spray (nitrous to freeze the FMIC) just an idea
Old Apr 25, 2006 | 07:36 AM
Rusty's Avatar
to answer any and all questions you may ever have in your lifetime....try this:
Old Apr 26, 2006 | 02:24 AM
You want the intercooler after the the air is compressed, not before. It miht help a little, but not nearly as much if you were to cool the air after it is compressed. This would result in a mess of piping that would in delay throttle response, and decrease boost levels, and overly complicate things.
Old Apr 26, 2006 | 03:13 PM
mattyfinch's Avatar
the stock intercooler in the redline is alot more efficient then a front mount intercooler could ever be, a front mount is nothing more then a psi stealer, causing delays through piping and being a less then stellar design. Granted they look cool, but the water/methane to air combo we have allows the car to boost decently stock, no real wasted horse power.
eventually someone will come out with an upgrade for the cooling system but i doubt very much it will be a front mount...... however i think the twincharger kit has a front mount for the turbo, but im not sure.
Old Apr 26, 2006 | 03:44 PM
badg1rl's Avatar
ahem...i guess u guys didnt see the pic of my car painted
Old Apr 26, 2006 | 03:48 PM
CTCOBALTSSS's Avatar
Hey BadG1rl please.... go on. I want to see the pics.
Old Apr 26, 2006 | 03:54 PM
badg1rl's Avatar
they are posted in the pics sec. but they are hard to see....i will have new ones again soon as i dont want to give everything away...i wasnt supposed to even post those in the first place. LOL
Old Apr 26, 2006 | 08:02 PM
ggarcia86's Avatar
we have an intercooler underneath the supercharger and an aftercooler inbetween the condenser and the radiator, at least that is my understanging
Old Apr 27, 2006 | 02:38 AM
That is correct. The intercooler is actually built into the intake manifold.
Old Apr 27, 2006 | 09:24 AM
l Sh1ft l's Avatar
I think she said in a diff. thread that her car got ran into.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Sep 27, 2015 08:53 PM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
