Intercooler End plate Dual Pass
Old Dec 8, 2006 | 09:08 PM
  #101
97cavie24ls's Avatar
Originally Posted by SS_SC_Cobalt
if you are doing it on a cavy you wont need the gasket, our pcv system is slightly different, this gasket cures the dipstick pop problem, lol
the cav 2.2 uses a modified gasket from the 2.0 gasket
we cut a chanel in it , so that the pcv port stays fuctional
havent put alot of miles on it yet , so not sure if the stick dip pops out , i know my friends redline does
ill have to let him know about it
Old Dec 8, 2006 | 09:18 PM
  #102
05redline's Avatar
SS SC Cobalt do you have any pics with the endplate installed along with the new surge tank? How long does it take to install?
Old Dec 8, 2006 | 09:38 PM
  #103
Blown 4-banger's Avatar
Just thought I'd let everyone know, the intake manifold gasket is reusable. It says so in the GM tech website. Plus I reused mine and and didn't have any problems. Hell I hit 20 psi the other night, and that would impossible with a leaky intake manifold gasket
Old Dec 11, 2006 | 07:34 PM
  #104
97 Z Me Go's Avatar
WEll anyone got this installed yet? Pictures pictures pictures!!
Kyle
Old Dec 11, 2006 | 09:18 PM
  #105
eastcoastz's Avatar
Blown 4-banger are you sayin you installed the new update intake manifold gasket and I use see a difference? Mine is on its way.
Old Dec 11, 2006 | 09:20 PM
  #106
No I'm saying I re-used my stock gasket. It works fine.
Old Dec 11, 2006 | 10:28 PM
  #107
eastcoastz's Avatar
Oh ok. I'm replacing mine tommarow with the updated gasket. I have boost getting by the gasket into the pcv system causing my crankcase pressure to pop my dipstick out.
Old Dec 11, 2006 | 10:34 PM
  #108
Wow you blew the gasket with a 2.8" pulley!?!?
Old Dec 11, 2006 | 10:41 PM
  #109
eastcoastz's Avatar
I think the dealer fucked up my intake manifold gasket because at 21k I had my head replace because of driver error(opps!) and when I got it back I would constantly blow the dipstick out of the tube until I replaced the O ring with a thicker one, but now this TSB came out which addreses this problem as a faulty intake manifold and now has this new improved manifold gasket.
Old Dec 12, 2006 | 03:53 AM
  #110
marzbarz's Avatar
man tired of reading lol . please some post pics and how to and >>sticky this shiit
Old Dec 12, 2006 | 05:08 PM
  #111
CobaltSS422's Avatar
no point in making this a sticky.... someone is holding out on pics and install
Old Dec 13, 2006 | 11:05 AM
  #112
lsjwannabe's Avatar
so do you hsve to make the brackets for the surge tank or can you buy them?
Old Dec 13, 2006 | 11:13 AM
  #113
SS_SC_Cobalt's Avatar
u have to fab them...
Old Dec 13, 2006 | 12:09 PM
  #114
cav101's Avatar
airbleed
SS_SC_Cobalt,
You seem to be the most knowledgeable on the end plate install.
The only thing after reading the instructions, is building the air bleed line. It looks like it comes from the reservoir with the .040orfice and the press in fitting. Does that line just hang down or does it connect to some ware on the intake.
Old Dec 13, 2006 | 10:44 PM
  #115
spaz's Avatar
fitting for the end plate
It will probably have to be welded or jb welded in place. I have a picture but can't figure out how to post it. Here is the link.
http://www.holley.com/984212ERL.asp
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
