Intercooler mods
Old Dec 21, 2021 | 07:14 PM
Smc252's Avatar
Intercooler mods
I have a large bumper-mountable intercooler radiator coming, and I have seen how the stock i/c radiator is getting heatsoak by the engine coolant radiator, has anyone relocated the stock one (in front of the a/c condensor) to decrease temps or do people often just bypass it completely? The added capacity sounds nice but not if it comes with higher I/C water temps.
Old Dec 22, 2021 | 10:37 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Some people will run it in parallel, some will bypass it.
If you run it in parallel, have the hot water go through the stock unit first, and then through the aftermarket unit.
Added capacity also helps with maintaining lower I/C water temps; which is why the Option B tank is a really good modification, as well. Think of your I/C water system like a pot of water on a stovetop. The larger the pan and the more water you have... the longer it'll take to heat up/boil.
Kolt
Jul 6, 2015 08:37 PM
jmo2010
Nov 18, 2010 10:52 AM
JshLnsctt
Apr 16, 2010 09:33 AM
Tmiller
Sep 9, 2007 09:40 PM
TheDriver!
Apr 18, 2007 06:35 PM
