Intercooler water sprayer?
Old Aug 31, 2007 | 08:06 PM
TurboTommy's Avatar
Hey guys...what do you think about this?
http://www.designengineering.com/pro...sp?m=sp&pid=57
Old Aug 31, 2007 | 08:30 PM
bl0wnbalt's Avatar
you would probably need a fmhe first and then the results wouldnt be what you expect because we dont have an intercooler, our aftercooler doesnt cool the air down it just reduces the heat soak of our intake manifold cause of the hot ass sc that sits on top of it
Old Aug 31, 2007 | 08:47 PM
phatnackySS's Avatar
might work if you move the heat exchanger in front of the ac condinser,or get a aftermarket heatexchanger, btw aftercooler,interrcooler same thing. ours is just a air to water intercooler insted of an air to air intercooler.
but in theroy it should work, it would cool the heat exchanger that would cool the water inside , that would then cool the air inside the intercooler. but money might be better spent on a water/ meth kit, or a dual pass endplate
Old Aug 31, 2007 | 10:14 PM
Maxim_X's Avatar
Umm, it does stop heat soak as well as cooling the air down.
Old Aug 31, 2007 | 10:45 PM
bl0wnbalt's Avatar
intercoolers and aftercoolers are not the same thing! one doesn't use water apposed to air to cool the intake charge, one cools the air and one cools the manifold plain and simple, with an intercooler you can directly chill the air with the fogger kit your talking about and the chilled, pressurized air goes directly into the engine, with our setup your just cooling off hot coolant and then heating it up again which is going to help heat soak but its not going to give you those instant tempeture drops that make n02 fogger kits so notorious for making big power
Old Aug 31, 2007 | 10:50 PM
burntorange's Avatar
it will really help make a difference, I am going to go with that later on. I need everything possible to cool down my car.
Old Aug 31, 2007 | 11:35 PM
i ment there the same thing in the snese that they do the same thing.
Old Sep 1, 2007 | 01:29 PM
TurboTommy's Avatar
I just bought it...for $80 you can't go wrong. I plan on setting it up with this heat shield :
http://www.jbodyperformance.com/new/...catName=JP0904
any other thoughts?
Old Sep 1, 2007 | 01:54 PM
sscobaltscZ06's Avatar
Got to hand it to GM designers to put it where they did witjh no direct airflow and sandwiched between 2 other hot items. Talk about design flaws.
Old Sep 1, 2007 | 03:42 PM
Mattman6's Avatar
please do not buy that heat sheild it is a waste of money Also the HE is sandwiched so you want be able to get the lines to the HE so have fun wasting money
Old Sep 1, 2007 | 04:32 PM
spike's Avatar
some evos have a water set up like the one up top stock it helps a little............not $80 worth though.....and u could have made the same thing from parts out of the junkyard 4 like $5 or $10.............idk.............and thats not a heat sheild it a heat trap...........lol
Old Sep 1, 2007 | 04:35 PM
cakeeater's Avatar
that's cause evo's have air to air intercoolers. You guys are gonna see minimal results with an intercooler sprayer. Is there any way to set up an ice-box for your cars? is there room?
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Sep 27, 2015 08:53 PM
